DefectiveAudioComponent
- Jan 20, 2008
Regarding the U70, I didn't find they were so much bass light, it was moreso that they sounded really hot and unnatural throughout the frequency range... it was basically just like my (heavily modified) KOSS Pro/4AAA tonally, with somehow worse transients and higher THD. Compared to my (stock) YH-1, they were damn terrible. They just sort of seemed to sound "off" in some way that I couldn't really describe at the time.
It's weird, since the Magnat RT-10 (menitoned earlier) uses the exact same drivers but somehow manages to be quite nice sounding, at least according to DAC...
Which prompted me to start experimenting. I'm working on transplanting them into an Audio Technica ATH-6 shell right now. Here's a WIP shot:
Cheers.
The drivers should sound ok if you play them outside of the headset, just holding them in your hands to your ears. If they don't sound good then, I wouldn't have high hopes for a transplant either.
The apparent problem with the U70 headset (that I never have heard) is the shallow vented-closed cups. I suppose that would reflect a lot of treble into the ears. I prefer the open-back PMB headsets.
That headset looks promising for a transplant - it looks quite similar to the large PMB headsets. Fully open back? I recommend light or no back damping to start with, good ear pads, and getting the driver as close to the ear as possible - even a small distance can reduce bass a lot. Depending on what pads you use, you might even try placing the drivers on the wrong side of the baffle. A bit of damping the front of the driver (dense dust protector) might be useful. (Traditional damping might work too of course, I suppose that's what you have there on the picture?)
