nick n
- Feb 3, 2011
Congratulations.
Anyhow there are others more suited to answer that than myself in here.
not really wanting to try and make a silk purse out of a sows ear
People have been experimenting with special foams for years (remember AudioCats and his HP ink-cartridge foam?).
I bought my first orthos, a pair of $79 Fostex T50RP's. Always been a Grado person, but there is a quality to the midrange that the fostex does very well. At their price I assume they are the bottom of the barrel as far as orthos go. I helped them by lining the inside of the cup with craft foam.
But not really wanting to try and make a silk purse out of a sows ear could someone recommend an ortho that has the midrange brilliance and bass texture of these fostex with less of the closed in distortion ? I've been reading about the HE-500 and HE-5LE, but really confused as to what is a step up in the ortho game for a Grado lover.
1a ) Keeping the acoustic resistance the same, but increasing the volume or time in which it takes for that resistance to be realized by the backwave... what's that do to the sound/diaphragm resonance? [thought experiment as an example:] ...conceptually cut an oversized disc of felt, place over some open-cell foam seated directly on the back of the driver, glue the circumference of the felt down to the magnet, place larger block of open-cell foam behind felt, then A/B that with a simple disc of felt glued directly to the driver.
1b ) What's that Technics-esque cavity do?
2 ) ... I'll admit, though, I don't understand where this [HP-ink] foam is coming from. How could you get a large enough piece to cover a driver from an inkjet cartridge?
3 ). Wouldn't a low density, insanely thin, high strength, slightly elastic polymer material (as equally unobtainable as TotalFoamHeadphoneCup and more expensive) for a diaphragm be key? What if we could get away w/o any damping like Stax? Polymethylpentene seems pretty PMP'in, although, I think it's tough to manufacture below 35-40um without pinholes. Its density is like whoa, though.
[0008] Preferably the diaphragm is clamped at its periphery and stressed to a bowed shape by contact with the resilient buffer and support member against at least the central portion on the concave face thereof. This is made from a specially selected grade of polyurethane foam. Alternatively, however, it could be made of soft down or mineral wool. ... and this element acts not merely to prevent the diaphragm from hitting the magnets, but also to tension the diaphragm and to control its resonance frequency.
And if we're cool with adding mass to increase structural stability of the diaphragm why not just have a non-driven honeycomb pattern on the reverse side ala T50RP? A foam diaphragm sounds like more work than it's worth to me, but maybe this is just my ignorance.
Last question. Wouldn't a low density, insanely thin, high strength, slightly elastic polymer material (as equally unobtainable as TotalFoamHeadphoneCup and more expensive) for a diaphragm be key? What if we could get away w/o any damping like Stax? Polymethylpentene seems pretty PMP'in, although, I think it's tough to manufacture below 35-40um without pinholes. Its density is like whoa, though.
You can't get the best amp under $100, that'd be silly. As for the best amp >$100 I don't know
My only amp is an O2 and it sounds great with my T50RP's.
I looked it up. Only found figures on pricing for prebuilt versions. How much would it cost to build one?
And any other recommendations for the best under or around $100?
So what amps are considered the best for a modded Fostex T50RP, for under ~$100? Or for any Ortho for that matter.
Originally Posted by DeathDomokun /img/forum/go_quote.gif
Does anyone know anything about the Sansui SS-10? I know there's plenty of info on the SS-100, but I can't seem to find much about the SS-10
