kalbee
- Nov 21, 2011
Calipers and/or rulers are unheard of in this industry, of course! That's not how we take measurements.
Only issue may be the large space there inside the pads that may need taming or shrinking.
oh hey that's a good idea. I have some assortments of foams I could try out.
Do you find the 1/4 port enough? For some reason I had settled on a 5/32 port after some trial and error with things, those are in very small cavity wooden sets though. Not sure how it would translate into a larger rear space. As well I think from what i have read, that if you have wool and things of that nature in there it lessens the need for a larger port.
Those are looking better each time you post them. Love the look and colour scheme. They do look like they are an off-the-shelf pair!
So am I correct in thinking the drivers ARE reversed? Anything notable about that orientation? What was it about that which made you mount them that way. Was it easier due to the part of the housing on that side being more flush?
Makes me really want to try them out...! How does the smaller cups/enclosure sound compared to before? The inside shape at least is not as irregular.
Just finished my own custom earpads for my HP-1 today as well! Easily said, as long as I don't know how to sow inwards like the way the stock pads are done (has to be machine done) and until I can learn how to cut foam, I'm not gonna get far. Looks funky, sounds terrible! Those are not treble peaks I got, that's a plateau!
Terribly overstuffed these things, and had to do a design change midway. Turns out way too thick and not soft enough compared to stock pads. Comfort is okay but the ear drums would say otherwise. Cannibalized a pillow for stuffing.
Well, soon for a mkII pad.
Oh and I might have understood why there's an extra flap on the underside of the stock HP/YH-1 earpads... its to keep a flatter and more regular shape so that the part stuck by double sided tape would not be disturbed when on the ears. And as safety blanket to get better seal.
**EDIT** seems by rolling tissue papers and stuffing them under the raised part of the earpads a good part of that treble plateau was tamed... got myself a somewhat smooth hill with max at 500Hz too. Any other ideas I can try before going to mk2?
Have a look as you stitch around the outer edges you will have to slightly bunch up a bit of the top larger side other wise it will at the end be a huge warped mess ( compensating for the larger outer diameter of the top leather ring.
