symphonic
- Nov 16, 2011
My overall system will still be headphone based (apartment dweller), but I want a flat reference speaker to measure my HRTFs. I want to do binaural simulation via convolution. I don't know anybody with nice monitors that I could borrow. Also, I will be moving within the next year and can't easily take a speaker system with me, so I don't want to buy anything heavy.
My first idea was to buy a nice full range driver and mount it on an open baffle. When I move I'd just take it off again. Then I saw that a 2-way speaker would probably be better. If the T50RP can be a temporary tweeter, I can buy a woofer that extends a bit lower and use it for tactile bass enhancement when I'm using the headphones as usual (for movies, games).
I'll be messing with VST host for the binaural stuff anyway. It doesn't seem so far fetched to use the extra channels of my sound card for software crossovers.
For a laugh I measured the bare T50RP driver from my laptop output at a distance of about 1 m (using a Panasonic WM61A capsule and Room EQ Wizard). Don't trust the absolute dB scale. Still, it doesn't look too bad!
I had the same thought with the 3 W rated power. I bet that I could even get enough volume from a simple headphone amp. I only want, say, 85 dB at 1 m.
