nick n
- Feb 3, 2011
So are you going to use those as a transplant then if so which driver?
I just finished off the Alder woodies with the new shallower pads, sealed around the rim of the SFI with thin layer of putty, added another disc of the superdense whitish felt so 2 total. Still a bit of a tapered airspace directly behind the back of the driver. I didn't "cone" the smaller recess at the very backs of the cups because I realized they were convexed from the tip of the smaller drillbit already, rather than being flat pits. They are not filled, as the discs of dampening felt sit level just above them. They're maybe 1/4" deep.
Used some black scavenged transparent speaker grille fabric for inside the pads to cover the drivers and make it look top notch.
I notice that the bass heavy tracks no longer seem to cause the driver to rattle slightly. I thought they were tight before but suppose not.
I wish you luck on the Maruni/Prefer search.
