Onkyo DP-S1 Rubato / Pioneer XDP-30R Private
Discussion in 'Portable Source Gear' started by steve80, Mar 8, 2017.
87 88 89 90 91 92 93 94 95 96
98 99 100
  1. miguel.yarce
    Hi! Did you solve your Tidal issue? I have the same in the xdp-30r.
    Regards!
  2. miguel.yarce
    Can you provide the case link? looks very nice.
    Regards!
  3. MrSlim
    If the DP-S1 is a Japanese sourced model, Tidal was never available on it. (search this thread for discussion about it). That also goes for the Pioneer version.
  4. miguel.yarce
    Thanks!! that is the saddest thing that I have read on this week.
  5. aqtaket
    I could not find the brown one now, here is the black case:
    https://www.ebay.com/itm/Japan-musashino-LABEL-Leather-case-CP-XDP30RLC1-N-Black-for-Pioneer-XDP-30R/163731326781?_trkparms=aid=555018&algo=PL.SIM&ao=1&asc=57475&meid=36ae453b41364ffa9ddefbca0ff24814&pid=100005&rk=3&rkt=5&sd=232499640550&itm=163731326781&pg=2047675&_trksid=p2047675.c100005.m1851
    It is nice, but a bit overpriced I think.
    Here is a cheaper version - dark blue leather:
    https://www.ebay.com/itm/Japan-musa...640550?hash=item36220ef8e6:g:fbsAAOSwT6JZx5ef
    I liked the "official" case, but again, paying $50 for a piece of plastic - that's weird :)
  6. miguel.yarce
    Many thanks!! Yes they are a little bit overpriced but unfortunately my 30r is very damaged the other owner wasnt carefull with it so it will be helpfull.
  7. mp3
    My DP-S1 is acting up, as in the lowest part of the touch screen becomes unresponsive. If I tap on the right bottom the touch registers as left bottom. Is there any fix for this, apart from a new screen?
  8. aqtaket
    What OTG cables do you guys use to connect to external DACs?
    If I need to hook up to a full-size desctop DAP (it has own power supply), do I need to use an OTG cable with micro B to Rubato, than connect another USB cable (2.0 A-B) to it? Will this combo work?
  9. nhumdorn
    If you read the previous firmware update, you can find a lot information about Tidal for DP-S1 so I think previously there was Tidal available there but has been removed since the latest firmware?
  10. WilcoRoger
    Tidal was never present on the Japanese model - Pioneer explicitly says so, explaining that as Tidal is not available in Japan, it is not part of the JP model
  11. lucifero13
    Good day! Has anyone tried using a 400gb and above to their daps? Am planning to jump to a 400gb from a 256gb.
    Reason is, I might change my 30r to a newer dap and usually daps nowadays only have 1 slot
  12. HippyChick
    I have the XDP-30R with 400GB in one slot / 256GB in the other. Absolutely no problems loading or playing
  13. shane55
  14. peter1480
    Same here 400gb in both slots no problems and still quite fast load and search.
    HippyChick likes this.
  15. nhumdorn
    Why having Tidal is inlegal? Don't understand much. User has to pay for subscription anyway. DAP is just a gate way for collect money. :frowning2:
98 99 100
