Welcome to the Land of Amplified Public Opinion.
All ears are welcome to tell us what you hear ...
One of the members here was just o'pining the fact that the Sendys are not giving them the soundstage and overall sonic impression of "large scale sound".
Perhaps you can tell us if its possible to build a small headphone, using the same driver you will use to build a headphone that is 2x as large, in area/space, and build both and have the smaller one, sound as "soundstage wide" as the larger headphone.
Is this possible? As i think of being inside of a car, that is inside of a very large cave. No matter what you do, you can't get the same soundstage inside that car, as you can get inside that large cave, outside the car.
Another way to think of it ......Say you are in a room, and the room has a small closet. You take your speakers and set them up in the room.....and you set them up also in the closet.
When you hear them, the room is going to be perceived as a larger space, because it IS, and that is soundstage..... whereas in the small closet.....small soundstage.
So, how can it be any different if you have the same driver inside a small cup, vs, the same driver inside a very large cup?
Is if feasible to expect a small set of planar headphones to complete (soundstage) with a much larger set of headphones?
Lets say you move the driver back as far as you can, away from the ear, inside the small cup, and you then take the driver in the large cup and you move it half the distance to the ear as related to the position of the driver in the small cup?
You still have a situation where the internal size of the larger space is going to present sound "larger" then a small space.
What is the workaround?
How do you get the soundstage inside a smaller headphone cup space, to sound as large as the soundstage in a larger headphone cup space, using identical drivers?
And in some ways, isn't this issue of perception <> disappointment, exactly the same thing that happens when you spend $3000 on a closed set of headphones, and the first thing you notice is that compared to even a $400 set of open headphones, the soundstage is smaller ..(no matter how many reviews you read by PRO reviewers who got their $3000 set for free, and said things about soundstage that actually are not true), that you found out after you spent all that money because of their review?
