Endcode
As I understand the B2 is remarkably similar but at a different price?
I only own the B2 so all I can do is speculate. The B2s, R-50, and MK II all use TWFK drivers, so keep that in mind too.
Deciding between B2's, VC1000's (~125) and a used pair of ER4S (~190) or similar. Anybody have thoughts? Comfort is huge, and I like to wear over ear... Not mandatory though. I had R-50's and want something similar, but a little smoother, just a touch. (maybe a slight bass quantity bump just a liiittleeeeee)
I know, and I like it, just looking for a different tuning I think.
Have you tried using an impedance adapter? Anything between 25-100 Ohms seems to work. Will give you slightly different results. Also try tip rolling a bit as R-50 stock tips are kind of a pain. I really enjoyed comply Ts-series with the R-50. I kind of miss them.
Interesting question. I would say:
$50-100: VSonic VC02 or Etymotic Research MC5, MEElec A161P if you want to jump into BA right away
$100-200: Etymotic HF5 or Rock-It Sounds R-50/VSonic VC1000/Brainwavz B2
$200+: Etymotic ER4S, j-Phonic K2 SP (if you're in Japan)
Customs: 1964EARS V6-Stage (balanced), JHAudio JH13 Pro (bassier), Hidition NT 6 (brighter)
I bolded my personal picks at each level.
Joker,
I recently purchased the MA750s. While I think I have really found a good sounding set of IEMs for the money, they kill my ears. For some reason they end up resting on my lower lobe and just become painful. I wear mine on longer flights so they have to be comfortable. So now, I am looking for something with a similar sound signature. If I had to be picky, the 750s are a touch thicker than I like in the lower mids and I could stand for a touch more detail in the upper registers. I do like the sub bass though. Not a bass head but there is something about the elevation in this region that I really like. What would you recommend I look towards in the same price range. I'll figure out the comfort issue on my own. I just want sound recommendations.
@ljokerl: I don't know how you keep up! With the number of times I have referred new users to this thread, perhaps it should be required reading for joining
joker, have you tried the ckm500 little sibling, the ckm300? I'm wondering because you did review the 500 before didnt you?
Joker,
What are IEMs like for gaming?
Big thanks.
What about Logitech UE700 and Fischer DBA-02 mkII, regarding their sound signature?
