(3A58) Xears Nature N3i
Reviewed Aug 2011
Details: In-ear headset from Xears
Current Price:
est $45 (30€) from xears.com with coupon code KLANGFUZZIS (MSRP: 89,90€)
Specs: Driver:
Dynamic | Imp:
N/A | Sens:
N/A | Freq:
6-28k Hz | Cable:
4’ I-plug j-cord
Nozzle Size:
5mm | Preferred tips:
generic single-flange; stock foam
Wear Style:
Straight down or over-the-ear
Accessories
(3/5) –Single-flange (3 sizes), bi-flange, and tri-flange silicone tips, foamhybrid tips, and padded carrying pouch
Build Quality
(3.5/5) – Like the other high-end Xears modes, the N3i uses painted wood and metal housings and metal nozzle filters. The sturdy nylon-sheathed cord does not kink the way some of the thinner ones do but can tangle a bit compared to the old Xears cables. Some driver flex is present
Isolation
(3/5) – Moderate with silicone tips and a bit better with the foamies. The large housings prevent deep insertion
Microphonics
(4/5) – Surprisingly low for a cloth cable and helped further by the j-cord configuration
Comfort
(3/5) – The housings are lightweight but quite large in diameter and clearly designed for a shallow fit. Unfortunately, the combination of j-cord and inline mic integrated into the y-split makes the N3i impractical to wear over-the-ear and the stock silicone tips leave a bit to be desired
Sound
(7.9/10) – The sound of the Xears Nature N3i bears a resemblance to that of Xears’ previous higher-end woody, the TD-III Blackwood, with the major differences being a slightly larger soundstage and less mid-forward balance. The bass of the N3i is the most powerful and prominent of Xears in-ears I’ve heard, narrowly beating out the PS120 and TD-III. The sub-bass is more powerful than with the XE200 and the entire low end is boomier and more full-bodied. Part of the reason is longer note sustainment – the N3i tends to have longer decay times than the other Xears in-ears. Impact is very sizeable and will probably be excessive for some but the N3i still manages to sound clean and resolving compared to the majority of bass-heavy mid-range earphones.
The mids are very smooth, as with the TD-III, but the N3i is slightly less forward in the midrange, which is partly responsible for the greater prominence of its bass. The midrange is by no means recessed but bass bleed is slightly more noticeable and the whole sound signature is richer, warmer, and thicker compared to the TD-III. Texture lags slightly behind the XE200PRO and is about on par with the TD-III, as are detail and clarity. For an earphone with a sound signature that places so much emphasis on the low end, the overall cleanliness of the N3i is enviable but unfortunately the clarity can be difficult to appreciate with all of that bass drawing attention to itself. In direct comparisons to other bass-heavy sets, however the clarity of the N3i shines and even the far more balanced Spider Realvoice could not beat the clarity or detail of the Xears on tracks where the bass did not overwhelm.
The treble of the N3i is low on sparkle but has good clarity and detail. It is not the sort of crisp, clinical treble found on some of my favourite analytical earphones but it works well to compliment the bass and midrange. It extends well enough upward and easily matches the other Xears models in overall proficiency. Presentation, on the other hand, is what most certainly sets the N3i apart from the already-spacious TD-III and lesser Xears models. The TD-III is already well above average in terms of the space it produces but the N3i sounds bigger still. The soundstage extends farther in all directions and whereas the TD-III leans very slightly towards intimacy, the N3i images more evenly across the sonic space. It can be fairly intimate when necessary but is also capable producing very good ambience. Instrumental separation is moderate, as with the TD-III, and airiness lags slightly behind the XE200 and XR120 models. On the whole it is a very solid presentation with a headphone-like feel and even well-tuned competitors like the Spider Realvoice sound a bit small next to the N3i.
Value
(9/10) – The suggested retail price for the N3i is quite high but the current sale price drops it right in the midst of the overpopulated mid-range bracket. For that price the build quality of the N3i is quite good and the day-to-day usability passable for those who can live with the j-cord and gargantuan housings. Signature-wise, the N3i is the most impactful of the three high-end wooden Xears models but still retains impressive technical ability and a large, engrossing presentation. It gives a sense of limitless power and makes no compromises and no attempts at civility with its signature. Quite simply, if you really like bass and can live with the form factor, the current price makes the N3i one of the best deals in portable audio.
Pros: Great overall sound quality; low cable noise
Cons: Large housings; moderate driver flex; not giftable for lack of packaging; j-cord may be an issue for some; bass can be too prominent
(3A59) Xears XE200PRO
Reviewed Aug 2011
Details: Flagship in-ear from Germany-based Xears
Current Price:
Specs: Driver:
Dynamic | Imp: N/A | Sens: N/A | Freq:
6-28k Hz | Cable:
4’ I-plug
Nozzle Size:
5.5mm | Preferred tips:
Wear Style:
Accessories
(3/5) – Single-flange (3 sizes), bi-flange, and tri-flange silicone tips, foamhybrid tips, and padded carrying pouch
Build Quality
(3.5/5) – Like the other high-end Xears modes, the XE200PRO uses painted wood and metal housings and metal nozzle filters. The sturdy nylon-sheathed cord does not kink the way some of the thinner ones do but can tangle a bit compared to the old Xears cords. The strain reliefs are ample and driver flex is low compared to the other Xears earphones
Isolation
Microphonics
(4/5) – Surprisingly low for a cloth cord and even better with over-the-ear wear
Comfort
(3.5/5) – The housings are lightweight but quite large in diameter and clearly designed for a shallow fit. The stock silicone tips still leave a bit to be desired
Sound
(7.9/10) – Whereas the similarly-priced N3i model pulls out all the stops in the pursuit of visceral bass and head-turning ambience, the XE200PRO is a slightly more level-headed take on the consumer-friendly sound common to the Xears earphones. Its bass is lower in impact and flatter than that of the N3i, with a punchier, crisper sound and slightly quicker note presentation. Sub-bass power and rumble are also reduced and the bass doesn’t bleed into the midrange as much as with the N3i or TD-III. In typical Xears fashion the low end is still anything but lacking but on tracks with plenty of bass the XE200PRO edges ahead of the N3i in resolution and clarity.
The midrange is smooth and detailed. It is similar in both emphasis and technical proficiency to the N3i model but there is not as much bass to get in the way with the XE200PRO. As a result, while the XE200 is not as warm and rich as the N3i, it textures notes slightly better and sounds more level overall. The overall clarity competes with the far more analytical XR120PRO and the timbre is quite good, as with the other higher-end Xears models.
The top end appears to be slightly more prominent than with the N3i and TD-III but still is not a focus of the sound signature. It sounds a tiny bit edgy next to the softer and slower N3i but doesn’t have any major adverse effects on the sound. Top-end extension is decent as with the other Xears models. Soundstage size is similar to the N3i but, while the N3i has the ambience of a large but enclosed space, the XE200PRO sounds a bit more open. It is not the most well-separated presentation but the layering is good and the positioning yields no surprises. It’s a well-rounded presentation to match a well-rounded sound signature.
Value
(9/10) – Completing the triumvirate of higher-end Xears wooden IEMs, the XE200PRO provides a slightly more balanced alternative with all of the technical capability of the N3i. Above all else, the XE200PRO is a well-rounded, relaxing listen that sacrifices a bit less fidelity compared to the N3i and TD-III models. It is much the same story with usability – the fit is less fidgety than with the N3i and the driver flex is less noticeable. The housings are still very large at the front but for this level of performance at the current asking price, I’m willing to live with far greater discomfort than that.
Pros: Great sound quality with a consumer-friendly signature
Cons: Large housings; not giftable for lack of packaging
