Trying2Learn
- Jan 28, 2015
2) VSD3S does'nt need an amp and are are very good driving raw. I have 429 and heard 449 (loan from my friend) 429 sounded great than 449 using my E11 & E12 but OK with E06 for its price and size, not bad.
3) no. AUX IN does'nt have the DAC functionality in cars/SUV....it an one of the external INPUT (AUXILLIARY) to the car stereo's AMP section. so if you connect an AMP between your source and car's AUX IN there's a 2 stage amplification (3 stages if used HO,and 2 stages if LOD used) which might result in distortion and more coloration and cld damage the speakers if they are very sensitive. So its not needed. but yes you can connect an AMP.
If you have an idevice you can buy a LOD cable and connect directly to AUX IN,best way,no AMP needed......
4) Yes a lighter can be used or a candle for that matter.you have to experiment for timing.
Hmm to be honest, I almost regret my purchase of the 449. Good thing they werent too expensive. I plug it in to my Iphone 6, maybe with amp it will be better?
