Isn't skin effect related to frequencies like 100kHz+?
With frequencies like those in earphones voltage travels through core of conductor
They actually don't sound much like the Stage 4; the Stage 4 sounds like the UE18 to me, which is not my cuppa' tea.
If I had to characterize it, it'd be a better extended and slightly more U-shaped, but much more resolving Stage 3. The timbre sounds different because of a different tweeter selection, and the midrange detail has more in common with the Stage 4U (flatter version of the Stage 4, the Stage 4 has too much mid-bass/lower-mid psychoacoustic masking). In a way, it brings together the Stage 3 and 4(U) in a balanced package.
I have no idea if the VE Stage 6 X1/2 is better or worse; but it seems like Felix is the more experienced of the two, and I was impressed by the build quality of Rhines. No idea if VE matches it or betters it.
Hidition announced their new CIEM: the Viento-R. Four drivers and two switches that control the timbre.
I have only heard the UE18 demo about 5 times, but that is quite unlistenable to me and the Stage 4 is better. Nice description, thanks!
That would be interesting to compare, the new VE vs. Rhines stuff. VE had an impressive build quality also, at least for the demos, but yes, Rhines is excellent!
I have no article about that, but insulator coating changes sound, one reson is leakage and anouther reason signals traport at surface of conductor. you can not see that affect at graphs.
If there was skin effect, the graph should have shown rise of impedance with freequency, and looks like it shows that with those headphone cables in the audio frequency, there is no real skin effect.
The coating is an insulator, it does not conduct. The electrons(the signal) only movies through a conductor and there is no leakage since there is insulator coating. The shielding is just metal sheet or braiding to cancel RF noise, and has no relationship to the conductor.
The Stage 4 definitely has more mids presence than the UE18; the UE18 has a weird mid scoop that makes it sound really funky. I feel UE was trying to create a really wide open sound at the expense of clarity. The UE18 does one thing really well, however --- delicate treble timbre, and that's the one aspect of sound that I felt was not as good in the Stage 4, otherwise, the Stage 4 is the better choice. It's confusing that UE could do so well with the UERM and yet bomb so hard with the UE18; the UE18 was made with the input of mostly musicians, though, and sometimes I really don't know what musicians want to hear. The UE18 is actually really complicated internally. It has several tubing mergers.
I don't know what the situation is with the Stage 4U -- it appears that it is an exclusive for JM-Plus, Rhines' East Asia partner for Japan and Taiwan, so people who want it will have to order through them. Timbre-wise, it sounds similar to the Stage 4, but the sound signature is much more like the Stage 3, with a very detailed midrange (more detailed than the Stage 3, and on par with the Stage 5). In fact, it's got one of the most detailed midranges I've heard, but does have a tendency to sound a little dry. Bass is similar to the Stage 3 in impact but with a little more in the sub-bass.
I wish I could listen to the VE6 XControl demo, but I'd have to take a two-hour trip just to hear it, so it's kind of out of the question, considering the schedule I keep.
The Viento-R looks interesting, but people are going overboard with the switch concept these days. What I'd really like to see is dynamic tube length adjustment, but I think that's an engineering impossibility (for now).
Hmmm, nice idea, but there are several problems. I'd say it would be only possible in universal IEMs, plus what would be a point of doing that? The outcome is pretty unpredictable sound-wise. Also you'd need around 1cm adjustment range to actually have any use of this.
