Jan 17, 2013 at 5:00 AM Post #2,448 of 4,841
The leading characteristic of the 5-way is that it changes based on the way the track was recorded, so much more so than other CIEMs.  I believe this is in part due to the ability of the 5-way to change its note presentation to that of the track.  Some tracks sound thick and warm while others sound crystal clear, making it a difficult CIEM for me to compare as other CIEMs don't change anywhere near the extent of the 5-way.  Are you experiencing the same thing?
As far as the 4-way, I believe the sound signature is closer to the 3-way joker reviewed, but with technical ability similar to the 5-way.
Not at all, the SE-5 is just boosted midbass (100-300Hz, centered at 160 Hz). If a track doesn't have much or any midbass, it won't be audible, obviously. That's the only place where SE-5 has a boost - it has cuts elsewhere, including some deep subbass cut (but not as much as many other BA IEMs, starts at 32 Hz). Plus the bass has a sharp, but correct decay quality.
The "chameleon" quality is due to flatness 500-3 kHz, then major cut 3k-8k. So depending on the track, it will be neutral, dull, sharp, soft, hard-hitting or bass boosted.
Highs are BA-like "over"crisp but quiet compared to lows. Not a veil, but highs are kinda shelved - no less extension though.
SE-5 *note presentation* stays the same all the time. Sharp but bit too thick bass with correct decay (it's hard to describe... perhaps a tiny bit of harmonic distortion?), good thickness mids, slightly thin treble.
That is unlike Westone 4 (the closest sounding universal), which had shorter bass decay, softer impact, thicker treble.
Jan 17, 2013 at 5:15 AM Post #2,449 of 4,841
That is unlike Westone 4, which had shorter bass decay, softer impact, thicker treble.
I also find a boost around 16-18k. well compared to all my other earphones (not headphones).
Jan 17, 2013 at 9:17 AM Post #2,452 of 4,841
I can't say that my ears agree with your assessment about the "major" cut at 3K-8K, as that is the area that I find changes from sounding cut to perfectly balanced to even bright at times.  To my ears, the 5-way has the capability to reproduce every note thrown at it accurately to my ears, from the fastest notes to very reverberant and thick ones due to the excellent PRAT.
Hi Joe,
Have you heard the MH335DW? Or 1plus2? If not are you planning on getting one?
I'm really curious with heir 8A, SE5, and fitear mh335dw.
No, I haven't heard either, but really want to hear the 335.  I have been in contact with Tralucent, but don't have a set date for when I will receive a demo, however the 1plus2 is not a CIEM.
Jan 17, 2013 at 11:50 PM Post #2,453 of 4,841
Got my UM Platform Pure 6 in today. Wow, that cable is a beast. The hardware box is surprisingly light weight though, which could make up for the cable if someone truly intended to use it as a portable. I'll probably do more "transportable" type use though.
It's strange seeing the innards of the CIEM portion minus the crossovers. Looks a bit empty, until you count the drivers and make sure that it really is a 6 driver setup. As usual, UM did a fantastic job with the build - I'll grab some pics and post them when I get a chance.
Jan 18, 2013 at 9:53 AM Post #2,454 of 4,841
Nice, I am looking forward to the pictures. Hopefully mine will be shipping soon...
Jan 19, 2013 at 12:25 PM Post #2,455 of 4,841
Looking forward to hearing your impressions (both) on the PP6. Joe, I have just tried the demo version of the Fitear MH335DW and they sound great (from 15mn of listening straight through my DX100). It would be awesome if you managed to review the demo version or even the real custom...I know they are 2000 bucks but...they might lend you demos...
Jan 20, 2013 at 11:25 AM Post #2,457 of 4,841
Thanks for sharing.  Yes, I would like to hear/review the 335!
Jan 21, 2013 at 8:06 PM Post #2,458 of 4,841
Hey Joe, another one to add to the overall list - http://www.head-fi.org/t/647328/ultimate-hearing-protection-systems-uk-soundear-pro-3-new-uk-custom-iems#post_9080324 - a new option for those of us in the UK.
