- Apr 28, 2007
Hi Girls Generation,
First, a reminder that I don't own the XP8000, but I am very familiar with the specs...
The XP8000 is rated at 3300 mAh (milli-amp-hours) for the 9- to 12-Volt jack that you would connect a cable to for the Stepdance. This means that if the manufacturer's spec can be trusted, the XP8000 will last at least SIX times longer than the 520mAh iPowerUs batteries - which means the XP8000 should deliver at least 24 hours of Stepdance use on a charge. (Don't be surprised if it's way less - we need input from a Stepdance owner to know for sure.) But already know it's probably 8 or 10 times heavier, if not more so, than an internal 9V battery.
I personally don't see the iPowerUs (or any other internal battery for the Stepdance) as being at all redundant to a large, heavy, external battery pack like the XP8000. They satisfy different purposes. I guess if I had to be stuck with only one or the other, I would prefer the versatitlity, capacity, and higher voltage (higher SQ) of the XP8000, but I currently use both types of batteries (small internal and large external) in entirely different situations - the internal battery for when I really want to keep the weight and bulk to a minimum, and my DIY 15-Volt Lithium Polymer RC batteries for when I want SQ above all else, but don't mind the extra weight and bulk.
I can understand that you want to stick to a budget - a quality I admire, truly - but you might want to hang on to the iPowerUs batteries, use them for awhile, wait to get feedback from ianmedium and others on how they like the XP8000, THEN think about ordering it in addition to your internal batteries.
That's just my opinion - please don't feel constrained to follow my lead. I respect that you have your own goals - possibly different from mine.
Mike
Mike
