Hey ianmedium!
The quest for 15-Volt battery packs continues!
I don't know what you've got up your sleeve, but I've got a challenging proposal for you: I was just now checking out the XPAL Tip Finder web page to see if I could confirm the availability of a
3.5mm O.D. / 1.3mm I.D. tip for the XP8000, as required by the Stepdance. I then stumbled onto their FAQ and found myself reading about the
XPAL Willy Cables - special, extra-cost cables that have
inline votage regulators built into them so that the XP8000 can be used with devices that require voltages higher than 12-Volts but lower than 19-Volts.
Guess what! They offer an XPAL Willy Cable (model # WI15) that's made to deliver exactly 15-Volts when plugged into the XP8000's 16- to 19-Volt jack! Saaweeeeeet!
This means that you could use the XP8000 as a 15-Volt supply for the Stepdance instead of as a 12-Volt supply!
And better still, you will enjoy a CONSTANT 15-Volts when using the Willy Cable WI15 - even as the XP8000 battery's output at the 19-Volt jack fades down to 16-Volts with use!
Compare that to using the XP8000's 12-Volt jack, where the voltage will drop with use from 12-Volts down to 9-Volts.
You have to be a registered XP8000 user to buy it, but it only costs $7.95 + shipping (here in the States, anyway.)
Here's a
link to the XPAL Willy Cable WI15.
When ordering online, just input that you're tyring to power a Toshiba Satellite M55-S1352 laptop.
That's one of several devices that requires exactly 15-Volts - like the Stepdance (which isn't in their Tip Finder database, of course.)
You will still need to get the correct sized tip (3.5mm O.D./1.3mm I.D.) that can be attached to the Willy Cable to plug into the Stepdance.
Are you feeling adventurous?
If you order the Willy Cable WI15, please measure the output voltage with a voltmeter BEFORE you plug it into the Stepdance. I wouldn't use it if it was anything higher than 15-Volts, and even then I have to say proceed at your own risk.
Go for it!
Mike
