Sep 19, 2013 at 8:04 PM Post #661 of 1,273
Just got my X-Sabre today, it's the new 2013 model with the switchable voltage on the bottom (had to switch it to 115V as it came as 230V), and man this thing is built like a tank, so heavy!! Hooked it up using USB the driver installation finished flawlessly. Initial impression vs my Bifrost Uber: warmer, but is it me or bass extension is a bit lacking compared to the Bifrost? I'm not getting some of the rumbling in the lows of certain songs that I seemed to be getting before (maybe because the bass is tighter and more controlled?).
Sep 19, 2013 at 8:26 PM Post #662 of 1,273
Perhaps some time to get used to the new sound is in order. I upgraded from Bifrost to Gungnir to X-Sabre, and the X-Sabre was a clear step above both in all categories.
Sep 19, 2013 at 8:35 PM Post #663 of 1,273
Yeah maybe. I'm only using the RCA out of the X-Sabre also. Gonna give it some more time. The sound is definitely warmer and less harsh than the Bifrost, but not too warm IMO. No more clicking lol which is good! There is a slight delay when switching sample rate though, for the DAC to lock.
Sep 21, 2013 at 5:56 AM Post #664 of 1,273
Did anyone experience high pitching noise (well, it's straight constant note) with X-Sabre? It's slightly noticeable in quiet passages of music (and extremely annoying when there is complete silence). My problem is that once I hear it I am somehow focusing on whether I can hear it throughout whole listening session and that ruins the joy. Btw, it occurs only in left channel, right channel is fine.
I have confirmed it's generated in X-Sabre - when I unplugged RCAs from amp, that tone disappears (plus the intensity is "manageable" with volume control). Then I tried to disconnect USB cable from X-Sabre, to be sure it's not coming from PC and the noise was still there. I even tried to switch power cables, plugging them into different outlets in my room (I usually have them plugged in IsoTek Orion power conditioner). Hell, I even unplugged laptop adapter and monitor and still same annoying high pitch noise in left channel.
I think it most likely is power related thing and something in our house is making our electricity very dirty. Also one of my adapters (for laptop) is making same noise when laptop is turned off (very annoying when I go to sleep). When I leave my X-Sabre turned on and listen very closely, its power supply does the same noise in smaller degree (at least I think it's the power supply), but that is not an issue with headphones on. However, it might an issue if this is actually the noise that leaks to the left channel (the question is - if it really is, why it is present only in left channel, not in right one as well?).
Sep 21, 2013 at 10:53 AM Post #665 of 1,273
You unplug from the amp and the noise stops. Something is causing a high frequency oscillation which is probably in both channels but better isolation in the right channel (very low level). If it doesn't see the amp load it is silent. Check for dc offset at your output. Change your cables to your amp (impedance matching could be a problem). If it is coming from your power supply then disconnecting the amp should make no difference.
Sep 21, 2013 at 11:05 AM Post #666 of 1,273
Weird. Can you try it in another room somewhere? Maybe even bring it to work/neighbor/friends house and see if it persists? If so, it needs a return to fix that issue. Too annoying to have to put up with it.
Sep 21, 2013 at 11:58 AM Post #667 of 1,273
I unplugged RCA connection to amp just to be sure it's not amp related problem, which it clearly isn't. I don't hear a thing in right channel, even when right channel is still in. I switched to my old RCA cables (which are like 20 times cheaper than the ones I have now) and nothing changed, noise is still there. I have one spare power cable and I tried 4 different combinations and noise in left channel persisted in all occasions. I even tried switching between IsoTek Orion and direct outlet (without any filtration) without any luck. I also tried my old amp and that left channel noise is still audible, but to much smaller degree. My old amp has a lot of background noise with highly sensitive headphones and I didn't hear the high pitching noise until I was way too high with volume - on normal listening levels it wasn't there.
I will try to set X-Sabre + amp up in another room, to see (hear) if it changes...
I really hope it's something I could fix (or something I know I can do nothing about), I really hate the idea of returning it, I waited so long for this and it will take long time to get it back again. Another problem is - I didn't buy it directly from Matrix, I got it from a french site http://www.audiophonics.fr/ , I cannot be sure that same issue will audible in other setups (I could barely hear it when I changed the amp, and I am pretty sure very sensitive headphones are needed to hear it).
EDIT: I moved amp+dac into another room, no change, issue persists. But, I noticed something very strange. When there is no RCA connected to amp, there is absolutely nothing to hear, complete dark background across whole volume range (props to amp for that btw). When I connect both channel (RCA cables), issue is starting to be audible in left channel at around 8 o'clock, annoything somewhere between 9 and 10 o'clock. However, when I switch channels (only on amp - so left channel from X-Sabre goes to the right on amp and right to left), noise is not switching channels! It still persists in left channel with same intensity as if channels were correctly connected. I guess this might not be X-Sabres fault after all...
Sep 21, 2013 at 6:27 PM Post #668 of 1,273
Reverse the tubes in your amp (switch them in the channels) and see if the noise switches to the right channel. This is sounding like your amp is at fault. May not be the tubes but it is the easiest thing to try.
Sep 21, 2013 at 7:03 PM Post #669 of 1,273
I just confirmed that the amp is causing troubles, not X-Sabre. At first I thought I have no chance of trying any other source besides X-Sabre, but then I remembered that like 2 years I bought some sh&$ty set of audio connectors and I could actually use aux to rca splitter. So I plugged my Cowon J3 in and noise is there! It seems that as soon as there a signal on input, amp generates a noise in left channel (nothing to do with tubes - I already switched them without any change, it's still in left channel). Thanks guys for helping me out, I am glad that X-Sabre turned to be innocent in this (not so glad the amp that costs half more than X-Sabre is at fault now). That being said, I am wondering how come when I hooked my old amp in the chain, I could still hear that high pitching bs in left channel, maybe I heard only what I expected to hear (psychoacoustics in it purest form).
Sep 21, 2013 at 7:28 PM Post #670 of 1,273
Dang, not the Svetlana! Glad you isolated the problem at least. Definitely try swapping tubes from left to right, see if the problem emerges on the other channel. Also I'd say try to plug it in somewhere else (another room or ideally another house altogether) which should be easy now that you know you don't need to lug the DAC along too. I wonder if the output transformers are picking up some interference or something? Would be ideal if it was a simple tube issue though.
Sep 22, 2013 at 4:47 AM Post #672 of 1,273
I tried swapping right and left channels on input, the noise was always in left channel regardless of how cables were put in. However, I am confused right now again - I just repeated a test with Cowon J3 as source and I got something I did not expect - there was no noise this time! As soon as I plugged X-Sabre again, bam, noise kicks in. Switching back to Cowon J3 - no noise.
Sep 30, 2013 at 9:58 PM Post #673 of 1,273
question for current owners: does anybody experience very occasional stutters/skips in playback? by very occasional i mean very rarely, maybe once every half hour or so, and it's just a single stutter/skip, music plays on normally after the short stutter, and if you rewind back to the same part it plays fine. im using usb, foobar2k wasapi push output, win7 pro 64-bit with latest 1.67 drivers, mostly playing 16/44.1 files. trying to find out what's causing it and because it's so rare i can't pinpoint exactly the source. i have just switched to wasapi event output, will see the problem persists.
Sep 30, 2013 at 10:12 PM Post #674 of 1,273
I sometimes have these issues, but not with X-Sabre. I think it's a memory / software-related issue.
Sep 30, 2013 at 10:22 PM Post #675 of 1,273
yeah i think its software related too. i switched from wasapi push to event as some claim that fixes the issue, but some others claim the problem happens on both types of wasapi :(. and i realized i may have exaggerated how often it happens. maybe once every few hours or so of continuous listening, maybe even rarer than that. i think i didn't encounter it for 3 days then today happened once. with this kind of low occurrence it's hard to pinpoint the issue, and hard to find info on this as well as many people probably won't even notice.
my wasapi buffer is set to 1000ms which is plenty i think. also i have plenty of ram so don't think that's an issue either. most likely wasapi plugin issue, though i seem to remember it happening in spotify which plays through system sounds.
