So of the stock tips, the foams seem to work the best for me, but I also ended up buying the Spinfit CP100-S (Should've gotten the CP155, but this works for now), and the Comply 400 Comfort +. The stock foams (size small) gives me the pretty good bass and slightly rolled treble for a bit smoother sound
To start things, I do like the Spinfit's bass extension. The fit is also fantastic!
I do notice the treble is brighter, a bit more forward in the midtone-treble (especially percussive hits), and there's even a bit of sibilance (or similar) brought back. The Comply is a tad too warm and the bass is not as good as the Spinfits. I do have the CP240-S coming in to compare. Should I also get the CP155 if I already have gotten my CP100 to fit? Would the CP155 with wider nozzle allow for the treble to step back a bit compared to the CP100?
I'm playing this off my LG V30 with Hi-Fi High Impedance mode enabled by tricking the phone with the 70 Ohm resistor plug
I suppose I can also get the Null Audio Arete III copper cable to roll of the treble a bit, too, right? If that works, then I may pair it with the SpinFit. What do you guys think? Also, is the Arete III worth getting over the Brevity?
https://www.null-audio.com/collections/iem-headphone-cable
As for the MD+, I'm really enjoying the sound and can even use a bit more bass at times. My right cable does pop off fairly easily, too, sadly. Hopefully the upgraded cable will fix things
