Broquen
cable 170 is upocc copper litz, and straight mmcx. but it's 86€ (shipping included, $5 sales coupon applied). better conductivity and plugs
Thank you for the advice. I'll keep a look on it!
https://www.amazon.com/gp/aw/d/B07DW6MK9P/ref=ox_sc_act_image_1?smid=A1WRDNWO5ZTILH&psc=1
https://www.amazon.com/gp/aw/d/B07F1VMQ3C/ref=psdcmw_13880171_t1_B07DW6MK9P?th=1&psc=1
https://www.amazon.com/gp/aw/d/B07SC9C9GG/ref=sspa_mw_detail_2?ie=UTF8&psc=1&th=1
https://www.amazon.com/gp/aw/d/B07SC9C9GG/ref=sspa_mw_detail_0?ie=UTF8&psc=1&th=1
Can someone point me to a decent cable for KPE looking for a 2.5mm
I had the 2nd cable, it's solid. Have/Had lots of YY cables from Amazon. Been meaning to get the 1st cable as my current one on my KPE is the 6 core SPC, want to try pure Copper to see if I see any differences, though I'm sure I won't so I've held off. I do like the look better than plain white.https://www.amazon.com/gp/aw/d/B07DW6MK9P/ref=ox_sc_act_image_1?smid=A1WRDNWO5ZTILH&psc=1
Received mine too. Using it with DM6 and Andromeda. Very very good cable. Soft and light weight. Will post a short review soon.Just got my ISN Audio S4 cable. Looks like good quality and sounds good as well. Did have to cut off the ear guides as it seemed that on one side the polarity was reversed (2-pin connector) and the ear guide was thus in the wrong direction.
VJC cables are available on rholupatWhere to find VJC cables?
And what is the best value for money MMCX, balanced 2.5mm right now, would use it with Tin T2.
Not knowing much about cables I bought the BGVP DM5, almost a year ago, they turned green, so how bad of a decision did I made?
https://s.click.aliexpress.com/e/k56dxn2
Link to the above mentioned cable.
THE SIDEGrade
Morning, as promised, was trying to make an impression regarding 165, compare to 130.
I want to include Abnormal, but when I tried it on, the Warm Sig already makes me reach 165... (I not to keen to warm Sig)
the gear I (only) used is my Solaris, with DX228.
flac songs :
Billie Eilish - Bad Boy
Billie Eilish - ilomilo
The Postal Service - Such Great Heights
Santana - se a cabo
Slime - Steppin' Razor
The looks...
Overall, quite same Sound Signature between the two...
165 better (small marginal ) then 130 in term :
- Darker background, the reason is because the Bass, Mid and High is thighter, that's what I exp (Song, Santana - Se a Cabo)
- due to thighter Bass character, it felt like the rumble even have layer detail (Song, Postal Service).
- Pint pointing excel, edit,this prob because darker background and thighter in each freq. (Santana - Se a cabo).
- lighter, edit. What to myself, the purpose of having 165 is lighter weight...
- seems better material for the mmcx connector.
130 > 165, in term :
- Dynamic acknowledged in low Volume... ( Volume 8 - 12). While 165 will start around 10 - 14
- more punchy bass in some songs (Billie elish and Slime)
- Mid felt more layer, but less detail and felt backward then 165.
- Soundstage a bit wider
My point, like the title said, is a sidegrade. a bit overlap may be...
Darker background (clarity) -> 165
better dynamic in low volume -> 130.
Which one I prefer to use... I let my ear and time judge.... each have some piece that I want...
Thanks to @hakuzen to inform me about 165. edit : it looks like EA Janus iBasso... hehehe I like...
additional :
165 all good...
@Slater Ur the man, keep inform us about your action. The truth sometime terrifying, but its necessary, and hope gents here can be mature enough to handle the info. Thank you...
edit, I can only dare open the jack case, no more than that, since I still want to enjoy the cable more
Update after using for 1 week and Reterminate 165 to 2.5mm.
Since 165 is copper based, I felt is a bit lack of Micro Detail compare to 130...
Now, I tempted to reterminate 130 to 2.5mm...
hehehe...
you can try last one from nicehck, 16 cores high purity OFC copper.what is the best cable under $ 10? I have trn 8 core but I listen to a little bit strange with tin t2. and I'm looking for something cheap that has quality similar to the original t2 or trn 4 core
