hakuzen
- Feb 9, 2016
the cable from your link seems to use mmcx for "new" etymotics.. they don't use standard mmcxI appreciate the insight. I may give this one a try. I'm looking for a decent cable with angled mmcx connectors and this appears to be the only one with any feedback. The other one I found on AE here:
https://redirect.viglink.com/?format=go&jsonp=vglnk_156061515513211&key=1e99669452acedd7650a94861c9354cb&libId=jwxpyt5d0101zlp1000MAb8dp0iyj&loc=https://www.head-fi.org/threads/low-end-cheap-generic-otherwise-bang-for-buck-cable-thread.891911/page-117&v=1&opt=true&out=https://www.aliexpress.com/item/LN006122-Black-8-core-2-5mm-3-5mm-4-4mm-Balanced-MMCX-Pure-Silver-Plated-Earphone/32915877932.html?spm=a2g0o.productlist.0.0.73d547bcxDBA2Z&algo_pvid=861a6965-ce34-405d-b6f8-18707b328f1b&algo_expid=861a6965-ce34-405d-b6f8-18707b328f1b-1&btsid=633a0e2b-7cde-420b-85e0-868c3e144e57&ws_ab_test=searchweb0_0,searchweb201602_1,searchweb201603_52&ref=https://www.head-fi.org/threads/low-end-cheap-generic-otherwise-bang-for-buck-cable-thread.891911/page-116&title=Low end. Cheap. Generic. Otherwise bang for buck cable thread! | Page 117 | Headphone Reviews and Discussion - Head-Fi.org&txt=https://www.aliexpress.com/item/LN0...chweb0_0,searchweb201602_1,searchweb201603_52
This one is 8 core, so a bit thicker, but description says it is very soft.
and quality of wire is not tested, while quality of cable 165 wire is superb, sound wise
