nope.
130, in
my list is this:
https://www.aliexpress.com/item/-/32952865240.html
https://www.aliexpress.com/item/-/32952957093.html
https://www.aliexpress.com/item/-/33001973013.html
ok. so your source has two possible outputs. 2.5mm TRRS (common) balanced, and single end 3.5mm TRS, and you want to use balanced one.
your adapter is usual 3.5 TRS male to 2.5mm TRRs female, to be able to use balanced ended cables (2.5mm TRRS) into single end outputs.
now we need to know the plug of your cable. is it 3.5mm TRS, or 2.5mm TRRS?
EDIT:
if your cable ends in 2.5mm TRRs jack (balanced), you don't need any adapter to plug it into the 2.5mm TRRS output, because configuration of pins will be the same.
if your cable ends in 3.5mm TRS jack (single end), you can't connect that one into balanced output (well, you could, by using an adapter, but the result signal wouldn't be balanced and there is risk to damaging the amplifier if the adapter is not right constructed, so better plug it into single end 3.5mm TRS output, you get better sound and not adapter required)
