JACK ADAPTERS
adapters with wire are comfortable, but add some resistivity and their quality depends of wire quality (together with plugs and solders quality).
short adapters (minimal or no wire) offer less resistance and you only depend of plugs and solders quality. in the other hand, they stress 3.5mm sockets harder. guess angled adapters will mitigate some of that stress compared to straight ones.
most adapters are 2.5mm TRRS balanced female to 3.5mm TRS male, but there also some 2.5mm balanced to 4.4mm balanced.
DC resistivity measurements (L+,R+,L-,R-, in mΩ):
short:
15. eidolic angled.........................................................10.3/10.3...9.4/9.3...1.9/1.2...2.7/3
25. astrotec AT-P01 angled..........................................15.5...14.8...2.4...3.7
05. eidolic styled straight...............................................6...7.9...4.4...8.1
30. yarbo (styled?) straight...........................................8.8...6.2...10.6...7.2
06. oyaide styled angled...............................................9.7...8.9...8.9...8.6
07. pailics angled.........................................................10.7...8.3...9.1...8.9
10. alo audio (styled?) A32(G) straight.........................8...10...15.5...8.2
20. oem/okcsc angled..................................................12...14...12...13...average (many measured)
08. rean/yongsheng straight........................................10.8...9.8...16.1...33.4
12. dd mini angled........................................................52.4...39.4...39.4...39.9
12. dd mini angled 2.5-4.4............................................52.5...44.9...51.8...68.3
with some cable:
62. eac upocc AgAu+copper litz 8c eagle.....................18.6/20.1...17.4/17.8...17.7/15.8...16.2/14.3
62. eac upocc AgAu+copper litz 8c eagle 2.5f-4.4m.....18.2/18.4...16.9/17...15.5/19.1...15.4/17
60. eac 7n upocc litz 8c eagle.......................................18.8...17.7...16.2...15.5
64. eac upocc AgAu+copper litz 8c eagle 4.4f-3.5m.....17...average (many measured)
50. FiiO BL35................................................................13...12...16.4...X
54. FiiO LB-4.4m 4.4f-2.5m............................................~25
- short adapters (minimum o no wire)
15. eidolic angled.....................................10.3/10.3...9.4/9.3...1.9/1.2...2.7/3
most expensive
links:
https://doublehelixcables.com/product/eidolic-2-5mm-trrs-3-5mm-trs-adapter/
25. astrotec AT-P01 angled......................15.5...14.8...2.4...3.7
links:
https://www.aliexpress.com/item/32860629855.html
05. eidolic styled straight...........................6...7.9...4.4...8.1
love these plugs, but straight
links:
https://www.aliexpress.com/item/32876989769.html
30. yarbo (styled?) straight.......................8.8...6.2...10.6...7.2
06. oyaide styled angled...........................9.7...8.9...8.9...8.6
07. pailics angled......................................10.7...8.3...9.1...8.9
loose socket
10. alo audio (styled?) A32(G) straight......8...10...15.5...8.2
links:
https://www.newbecca.com/product/539325396657
20. oem/okcsc angled...............................12...14...12...13..average (many measured)
cheapest, but nice built.
links:
https://www.aliexpress.com/item/32865122372.html
08. rean/yongsheng straight.....................10.8...9.8...16.1...33.4
loose socket, bad quality.
12. dd mini angled...........................52.4...39.4...39.4...39.9
......dd mini angled 2.5-4.4...............52.5...44.9...51.8...68.3
the 2.5mm socket is like those used into sources' cases, so expect longer durability (time will tell).
but conductivity is very poor (the worst by far). the culprit is the flexible gold plated ribbon/pcb used to connect the contacts (thin and not great material probably). the resistance is the same as some 1.2m cables (+plugs), go figure.
links:
https://www.aliexpress.com/item/4000164103882.html
- with some cable:
62. eac upocc AgAu+copper litz 8c eagle.......................18.6/20.1...17.4/17.8...17.7/15.8...16.2/14.3
......eac upocc AgAu+copper litz 8c eagle 2.5f-4.4m.......18.2/18.4...16.9/17...15.5/19.1...15.4/17
custom adapter from electro acousti (
https://www.aliexpress.com/store/5003206), using same wires than cable 175
7.5cm (not counting plugs). neotech (taiwan) oem up-occ silver 99%+ gold 1% alloy, and frozen 7n up-occ copper litz (best silver and copper wires in my stock, imo).
links:
https://www.aliexpress.com/item/4000231198864.html (custom wires and plugs)
8 cores of 28awg, 25AWG/signal.
https://www.aliexpress.com/item/33046978735.html
https://www.aliexpress.com/item/33008255130.html
very high quality durable plugs (eagle, rhodium plated over gold plated beryllium copper):
https://www.aliexpress.com/item/1000007394708.html
https://www.aliexpress.com/item/1000007901246.html
https://www.aliexpress.com/item/1000007708309.html
60. eac 7n upocc litz 8c eagle cable............18.8...17.7...16.2...15.5
https://www.aliexpress.com/store/5003206), using same wire than cable 171
8cm (not counting plugs). neotech (taiwan) oem frozen 7n up-occ copper litz (best copper wire in my stock, imo).
links:
https://www.aliexpress.com/item/1000007631873.html
very high quality plugs (eagle, rhodium plated over gold plated beryllium copper):
eagle 4.4mm female socket is not the usual cheap chinese socket. it is built for many insertions.
3.5mm TRS male and 2.5mm TRRS male versions available as default options.
links:
https://www.aliexpress.com/item/4000227685853.html (eagle durable gold plated copper)
https://www.aliexpress.com/item/1000007579285.html
50. FiiO BL35 cable:..................................13...12...16.4...X
couldn't measure ground to R- resistance, because the contact is very deep into the socket.
you'll have to push 2.5mm jack all way long to get sound at right side.
links (many sellers):
https://www.aliexpress.com/item/32890820615.html
i don't like much the plugs. 4.4mm female socket looks cheap.
https://www.aliexpress.com/item/32969207148.html
