hakuzen
- Feb 9, 2016
i assume you mean cable 170, not 70.I am thinking on buying #70 or #165. I have a niceHck M6 which can be overwhelming and flabby bass, but I did get cable 151 (ISN 8) and that has tightened and cooled the bass nicely and really has let the M6's imaging and resolution shine. Would cable 70 or 165 be an upgrade and still tame the bass a bit?
yes, they both are an upgrade from isn audio cables. wire used gives you a clear step up in terms of sound.
price is fantastic for these cables during the sales plus coupons. i'd get another one, but i'm served (3 units).
but if you want slight brighter sensation (bass taming), you should go for silver plated up-occ copper litz or hybrid (silver plated copper + copper) versions (not in my list yet):
166. taiwan silver plated 7n frozen up-occ litz copper, 4 cores 28awg PE sheath (eidolic styled jack, taiwan imported mmcx). light brown sleeve cores + transparent sleeve cores (silver color)
0.08mm*19(OD:1.08mm/27.3AWG)*4c?
links:
https://www.aliexpress.com/item/-/32994248213.html
https://www.aliexpress.com/item/-/32997399146.html
https://www.aliexpress.com/item/-/33001933222.html
wire:
https://www.aliexpress.com/item/-/1000007631873.html (copper!,litz) + https://www.aliexpress.com/item/-/33006890732.html (litz)
169. taiwan silver plated + copper (mixed into each core) frozen up-occ litz, 4 cores 28awg PE sheath (eidolic styled jack, taiwan imported mmcx). transparent sheath, silver+copper colors
0.07mm*7spc+0.09mm*5copper(OD:1.08mm/27.3AWG)*4c?
links:
https://www.aliexpress.com/item/-/32996895840.html
https://www.aliexpress.com/item/-/32995698807.html
https://www.aliexpress.com/item/-/33002688074.html
wire:
https://www.aliexpress.com/item/-/1000007736919.html (litz)
these are my best recommendation, together with 165 and 170 (copper). once you listen with these taiwan cryo UP-OCC cables, you won't go back
