Guys,
Do any of you guys know a where to get a 325is fully upgraded into a Magnum? I have a 325is lying around, but I don't know much about modding myself so I'm very afraid of wrecking my cans.
Thanks,
Le
There are a few options ...
If you want to created exactly what Rhydon used to provide, it took me a few years to:
- Hunt down my own Magnum v4 drivers
- Got some SR325is cups (you don't have to do that)
- Hunted down a headband assembly (you don't have to do this)
- Braided my own cables (you don't have to do this either)
- Looked for aluminum inner shells/sleeves that would fit the v4 drivers, eventually gave up, and asked a machining shop to do it for me (see my ad in the signature).
Now you have options, as the only things you need are the drivers and the cups.
For drivers, you can either hunt down the v4s, which were intended for aluminum cups (or so I've read), or you can stick with the v5s and have them sent directly to you from Turbulent
For cups, you can
a) Get wooden cups, which are relatively easy to find, or if you have the skills (which I don't), make.
b) You can keep the SR325is cups and try to keep the plastic sleeves when removing the 325 drivers (extremely hard to do without damaging the drivers).
c) You can keep the SR325is cups and make your own sleeves in plastic, wood or aluminum (or buy a set from me
The process took me a little over two years, but I wasn't hunting for these things around the clock, so if you are more dedicated, you can get it done much quicker. But why rush it? The hunting part was the fun part for me.
