Grado Fan Club!
Oct 29, 2023 at 5:31 PM Post #63,061 of 66,258
I have the chance to buy used GH4. It would be my first Grado and NEVER listened to any Grado at all.
How much money are they currently bought/sold for? since they are limited to 1000 pieces, is it possible that they will increase in value over time or at least not lose value for many years afterwards? Thanks :)
E: Oh, and what is G and L pads? Would changing the pads improve the soundquality aswell? Thx!
Oct 29, 2023 at 5:55 PM Post #63,062 of 66,258
I guess they should be about 400-600 bucks. And i don't see them losing much worth in the future as they are limited and even the non-limited Grados keep their worth quite well. I wouldn't count on making much money by buying and reselling though.
The GH4 come with L-pads, those are the foamy things that touch your ears. Don't change them, experience them as they are so you get a feel for the headphones (Grado designs the drivers to sound best with the pads that come with each headphone type). Maybe in the future you could try other pads. In my experience it's never really worth it though, others disagree.
Oct 29, 2023 at 6:24 PM Post #63,063 of 66,258
How much money are they currently bought/sold for? since they [GH4] are limited to 1000 pieces, is it possible that they will increase in value over time or at least not lose value for many years afterwards?
Not great. Typically the models that are valued above retail are legendary ones like the HP2, or some ultra rare variant like the SR300 w/Blackstar drivers, PS1, or more recently, the Oreo, of which 45 are known to exist as part of a contest. The GH4 never really got much hype.
Oct 29, 2023 at 6:27 PM Post #63,064 of 66,258
Thanks an lot, will take care when checking them tomorrow. Btw how is the comparison between GH2 and GH4? Which you like more?
E: Oh and is a Qudelix 5K „good enough“ to drive the GH4? Thanks! :)
Oct 30, 2023 at 2:18 AM Post #63,066 of 66,258
I only know the GH2 which got a lot of good rep on here. But there are also some GH4 fans around. For obvious reasons there aren't many reviews of the whole series. I think i once read that they all sound pretty similar. If the GH4 is anything like the GH2 then you can throw nearly any source at it and it will sound great.
Oct 30, 2023 at 8:11 AM Post #63,067 of 66,258
Oh, most recently, a sealed Bushmills (2013) sold for $1000 on eBay. Not bad considering the original price was $400. That one had special display packaging and was most famously known as Grado's only semi-open headphone: the vents are just tiny slits on the side. (OK, there's also the SR40 but that one is best left to history. :relaxed:)
Oct 30, 2023 at 11:45 AM Post #63,069 of 66,258
Some Hemp to dispel the chill of a rainy, windy 45F degree day …
Oct 30, 2023 at 12:22 PM Post #63,071 of 66,258
I know they're plugged into the violectric, but I was pleasantly surprised how good the hemps sound with the wa6se. brought them to life
Hemp does sound great with a well-designed OTC tube h/p/a. ✅
Oct 30, 2023 at 7:44 PM Post #63,072 of 66,258
Sound signature of all Grado's changes audibly with different earpads. It doesn't necessarily improve the sound quality, but allows to easily fine tune their sound to your preferences. I don't have the frequency response graphs for GH4, but I've recently measured the very similar GH2 tested with 6 different earpads, please see the graph attached.
It shows how loud the headphones reproduce certain frequencies. The graph can be divided horizontally into 3 sections: on the left side of the graph you have the lows or bass, in the middle there are, well, the mids, so vocals, guitars and similar instruments, and on the right you have the high pitched tones or treble.
Frequency response curve of the stock GH2 and GH4 L pads is colored pink and the G pads are colored green. If you change the stock L pads to G pads on GH4, you can expect to hear less bass and more treble. This will make the sound of GH4 more detailed, but also more "dry" to the lack of bass.
Oct 30, 2023 at 8:08 PM Post #63,073 of 66,258
Very interesting, thanks for this post!
Which earpads I need, If I want boost the Lows/Bass? :)
And: Isn’t it common to adjust the EQ individually on the GH4, right?
Cheers!
Oct 30, 2023 at 8:17 PM Post #63,074 of 66,258
…. how is the comparison between GH2 and GH4? Which you like more?
• I own both GH2 and GH4. With these, I use TTVJ Deluxe Flats (F-pads), Nyczaj Audio gimbal/rod assemblies, Turbulent Labs headbands.
• Sound? Both are very well balanced, of even tone and extended frequency range, portray a spacious soundstage with excellent detail. In these regards, GH2 and GH4 are quite similar.
• To me, the primary differences are in the onset and decay of notes/chords. GH2 has ‘quicker’ onset / decay; the onset / decay in GH4 sound ‘lingers’ a bit. Is this bad? Not to my thinking. It is analogous to the acoustics of a music venue varying with seat / table location.
• These differences, I believe, are due to the relative hardness of Cocobolo wood in GH2 versus the relative softness of Norwegian Pine in GH4.
Oct 30, 2023 at 8:21 PM Post #63,075 of 66,258
Cheers!
For boosting bass you can try one of the aftermarket fabric earpad options, like Nyczaj, Dekoni or Beautiful Audio, frequency response curves for them are also present on the graph from my previous post. Fabric covered earpads create a more sealed acoustic chamber between the headphone driver and your ear resulting in audibly more bass. On top of that they're generally much more comfortable than stock foam pads. Be careful though, too much bass might veil the higher frequencies resulting the sound of the headphones to become muffled or muddy - because of this leather pads are generally not recommended for Grado's.
And yes, you can also get similar effects using the digital EQ, but you'll be missing out on the comfort aspect. I use fabric pads for all my Grado's because the stock foams hurt my ears when I use them for too long :sweat_smile:
