Grado Fan Club!
Aug 5, 2023 at 7:07 PM Post #61,982 of 66,258
Ya kidding, right?!
Yep that is what I found out when I cut the 6.5mm plug off a 325x to fit a Xlr
With a multimeter I could not separate the blues they all showed a dead short to each other when belled out.
Where as the reds and the white you could bell them out individually from the plug end to the driver
Aug 5, 2023 at 7:09 PM Post #61,983 of 66,258
Ahh another thing.. I read on here a few days ago that iOS only uses aac. Which is simply not true for nearly two years.. Apple has introduced lossless and 24-bit/192 mode on all of their music in Apple Music. There are also many other apps that can pull off lossless and high-res using iOS. Though I do think really even aac is good enough and very good sounding. If you want to kick it up a little notch then try lossless on iOS. You may like it if you have the bandwidth and a proper data cap.
I‘m using flac 24/96-192 on iPhones for about 8 Years.
There is no limitation to 16 bit or 48 kHz in (intel’s) Lightning or iOS and never was.
Only their ‘Music‘ player, the thing in iTunes didn‘t work with it.
Put Onkyo, Hibiki, or one of the gazillion other to the phone add a Mojo2, xDSD Gryphon, Q3, Chronos, M12, ... and enjoy your music.
(If 96 kHz is enough and ESS sound signature is no issue, give the Dragonfly Red or Qudelix (love the app) a try)
But yes, in Bluetooth I really miss aptX LL.
Aug 5, 2023 at 7:35 PM Post #61,984 of 66,258
Anybody spend the extra 170,- in a balanced cable?
Maybe measure pin 2 against 4?
Aug 5, 2023 at 7:50 PM Post #61,985 of 66,258
The way Grado designed the 6.5mm standard is excellent as it uses separate core but keep true to SE.
Lesser companies could use one (blue) - core to the Y then split it.
This may be one of the reasons why Grado are so insistent on non detachable cables
Aug 5, 2023 at 8:58 PM Post #61,986 of 66,258
I do just fine on the lightning adapter on 16bit 44.1 kHz. No sense in going further for me as I use red book compact discs as my reference.
Aug 5, 2023 at 9:14 PM Post #61,987 of 66,258
With a well-engineered DAC, especially the R2R type, and a robust CD transport, there is musically plausible sound to be had from the 16/44.1 disc 😀 !!
Aug 5, 2023 at 9:25 PM Post #61,988 of 66,258
With a well-engineered DAC, especially the R2R type, and a robust transport, there is musically plausible sound to be had from the 16/44.1 disc 😀 !!
Can’t beat the selection either. I need to look into a R2R DAC. And explore price points. A friend of mine from California who is like an independent audio repair/used to be dealer, has an extra Jolida tube headphone amp for a good price. He says he will ship it out to me for free to see if I like it, I’ve talked with him off and on for 20 years so he trusts me. Be assured this is the exact same amp I showed you by Black Ice Audio. I will report my findings with it.
Aug 5, 2023 at 9:32 PM Post #61,989 of 66,258
I like the looks of the Jolida more anyways. Especially in silver!
Aug 5, 2023 at 9:41 PM Post #61,990 of 66,258
Nothing on the horizon that has been mentioned out loud. John is always looking forward for the next up . I would think that the x Series has lots more good mileage and life left and it has been very popular. As John seeks out the next approach to performance. The PS2000e was designed & done over the course of almost two years.
I’ll say it here (again): Let’s have an RS1x, obviously with the x-driver, which features an all-cocobolo wood housing. An ‘updated’ GH2, if you will. Please?
Aug 5, 2023 at 9:59 PM Post #61,992 of 66,258
The rs1x usually looks pretty ugly with that naked hemp wood behind the cocobolo in pictures. At least I think so. Maybe it looks better in person?
Perhaps you should reconsider …
[with Turbulent Labs headband and Nyczaj Audio gimbal assemblies] 🤷🏻‍♂️🙂.
