I had the same experience, very comfortable but ruined the sound.I tried the BA G pad and it did not sound good on any of my Grados. The only thing good it was soft & comfortable on the ears. Absolutely killed the clarity & balance on any of mine. I am glad it was a loan from a friend who had the same opinion.
Grado Fan Club!
- Thread starter Vikingatheart
- Tags
- 1000hours burn-in minimum 1000hours hearing damage minimum dynamat grado grado hf3 grado-gs1000 grado-head-fi-series-hf-2-headphones grado-igrado-black grado-professional-series-ps500-headphones grado-rs1i-reference-series-headphones grado-sr-80 grado-sr125i-headphones grado-sr225i-headphones grado-sr325is-headphones grado-sr80i-headphones grado-statement-series-gs1000i-headphones nhoord nhoord red v2
But did you try shoving a Grado G inside to maintain the proper driver to ear spacing?
Even with the L size, the default foam is too cushy, and though comfy, didn't work for me. Foam rolling to a real L made all the difference.
No, I used them with the foams that were included. If I recall properly none of the documentation said to use the grado pads inside the beautiful audio pads.But did you try shoving a Grado G inside to maintain the proper driver to ear spacing?
Although the BA pads are designed to allow foam rolling, I have to admit it didn't immediately occur to me to stick a whole L pad inside, either.
TooFrank
- Feb 17, 2017
Just received the geekria pads, used them initially with the sr80i s and wauw. Now trying them out with my new hemps. So far very good indeed. Softer than the original L pads, and apparently gives a better sound than the stock flat pads (which I otherwise really enjoy)
Gippy
- Dec 2, 2016
Cool! I'm glad that you agree with my recommendation
In other news, I sold my GS2000e on CAM for $1000 CAD. You'll be missed
elvergun
- Jul 15, 2004
Hey guys, new here. I have a set of Grado Sr60 with custom mahogany cups and new pads along with some mods. im looking for a better set of grados that have a bit more bass and clarity, what would you recommend?
carboncopy
I don’t know. I just love my RS2e and I wouldn’t buy it after watching this.
Gippy
- Dec 2, 2016
Haha, after spending the effort of pad rolling for my Hemp review, I'm now rolling my eyes at any professional review that doesn't bother to do the same.
Joaquin Dinero
Whats your budget ? I think pretty much any of the current lineup would be an upgrade for you, from an $80 SR60e to $2400 PS2000e.
You probably should just get them all to be extra sure
i was thinking of just swaping my drivers for turbulent x or Symphone v9. has any one tried these out?
carboncopy
Maybe not the best wording. I would totally buy it again, now that I know how it sounds. But without experience and watching this..
elvergun
- Jul 15, 2004
Turbulent X drivers, from what I've heard, do not have a lot of bass. You might be better off with Symphone or Nhoord drivers.
Another thing you can do is vent your SR60 drivers...three holes should do the trick. I just finished a build with SR60i drivers (three holes) and there is a day and night difference going from stock to vented drivers. Everything improved -- the sound stage is wider, the highs are not as sibilant and the drivers can actually produce bass (both mid and sub bass).
If you are already thinking of changing drivers then you have nothing to lose. If you don't like what you hear then you can try an aftermarket driver. A fellow member loaned me his modified Turbulent X (two holes and some other changes) build (I sent it back to him yesterday...sniff) and it was freaking incredible. He informed me that the stock X is not that good. I was thinking of getting the X driver and modifying them, or buying some Nhoord drivers, but the more I hear my vented SR60s the more I'm satisfied with what I've got.
Thanks for the info, my current sr60s are hole punched as it was one of the first mods i did, they sound good but im itching for a touch more bass. Would sr80s 125 or 225s have more bass?
Total: 16 (members: 1, guests: 15)
