Grado Fan Club!
- Thread starter Vikingatheart
- Tags
- dynamat grado grado hf3 grado-gs1000 grado-head-fi-series-hf-2-headphones grado-igrado-black grado-professional-series-ps500-headphones grado-rs1i-reference-series-headphones grado-sr-80 grado-sr125i-headphones grado-sr225i-headphones grado-sr325is-headphones grado-sr80i-headphones grado-statement-series-gs1000i-headphones nhoord nhoord red v2
As one who didn't care much for the SR series (non-e versions) sound and comfort the Merino pads on these older original and "i" series changes the sound enough that I think many might actually like the sound and the comfort is quite a bit better than any S or L pad that I've tried to date. The pads came with two different foam inserts and while they both change the sound the open cell foam insert has much less influence in the sound and would be my preferred choice while those that want a warmer fuller sound will probably like the dense foam insert. With that said I still prefer G-pads but since my SR225e, SR60 and RS2e are modded the Merino pads don't quite work well with them making them all a bit to warm and killing some of the Grado "magic" that I like. I'm trying to get a friend to bring over her PS500 to see if the Merino pads are what they need since my listen with them left me unimpressed since the sound was thin and lacked any bass with highs that were a touch harsh/hot with some tracks.Thanks.
I was mostly curious about their sound because I had tried the Ear-Zonk vinyl pads on my 325is and took them off in less than 30sec...they totally destroyed the Grado sound. This doesn't mean the same goes for the pads we're talking about, though, so that's why I ask. How did you like them?
@DavidA Thanks for the informative reply.
I'm mostly just curious about the sound, I'm one of those who don't have a comfort issue with the stock Grado cushions at all.
stvn758
- Jul 13, 2008
If they cut out on you then a re-cable would be nice but I'd go a different way and make the cables detachable at the cups using SMC, 2.5mm or 3.5mm jacks. It will make it easier to change cables so you can easily change your cable in the future. I'd used SMC since the jacks are small and the connection is quite secure, like this on my RS2e:
I just got mine back from Custom Cans, nice cable, they also put the jacks on the old Grado cable as well so that works now. So when I use the balanced cable it's truly balanced, yes?
I am still trying to get my head around the fact that most balanced cables and amps have just one four pin XLR, it gets very confusing.
PhenixS1970
Benelux dealer made me an offer I couldn’t refuse and traded in my GH2 for.....the GS3000e . Will most likely receive it end of next week and will let you know what I think. Blind purchase but none of my Grado cans disappointed me (and I still have the ps500 and GH1 for portable use).
got any pictures of the new cable?I just got mine back from Custom Cans, nice cable, they also put the jacks on the old Grado cable as well so that works now. So when I use the balanced cable it's truly balanced, yes?
As for balanced jacks / cables there are different types: TRRS: 2.5mm, 3.5mm and 4.4mm (usually found in DAPs), XLR single 4 pin, XLR dual 3 pin, TR/TRS 6.3mm (full size amps)
Shane D
I'll be curious to hear your reaction. I don't think I will ever sell my GH2's, which is why I am thinking about having them modded. To me, they are lifers. But I suppose who knows for sure.
Shane D
tiobilli
- Nov 7, 2011
Lucky @PhenixS1970 GS3000e are gorgeous, very light, and sounds excellent. I tried in a demo few weeks ago and I liked a lot, more bass than Gs2000e.
gregorya
- Mar 5, 2011
That sounds like a really good offer... mind you, I haven't heard the GS3000e but they certainly are intriguing. Have you heard any of the Statement Series models before?
Looking forward to reading your impressions... congrats!
Shane D
I would LOVE to have 3.5mm inputs and a 4.4mm connector so that I could use my balanced cable with my Sony DAP. I think that would be audio bliss. Made a very large difference with my Sony Z7's.
Shane D
Did you mod your Grado to have removable cables? and if you did what are the connectors at the cup end?I would LOVE to have 3.5mm inputs and a 4.4mm connector so that I could use my balanced cable with my Sony DAP. I think that would be audio bliss. Made a very large difference with my Sony Z7's.
Shane D
Here is a suggestion if you have a few different headphones and a few different DAPs/amps with various balanced or SE output.
1. Wire all your headphones to a balanced connector (4pin XLR)
2. Make a adapters:
a. 4pin XLR to 6.3mm/3.5mm SE
b. 4pin XLR to 2.5mm, 3.5mm or 4.4mm balanced (based on what you need here)
This way you can use any headphone on any amp type of output.
Shane D
2. Make a adapters:
I have not had my Grado's modified yet. My DAP does have a balanced output via a 4.4mm connector.
Is 3.5mm connectors on the cups tricky or not recommended? My Sony and my Meze will work work with that configuration, although the Meze needs slimmer 3.5mm connectors for the headphones.
Shane D
ruhenheiM
- Dec 27, 2010
Shane D
i don't think it's tricky,few people already mod their grado like that but i'm not sure how reliable for the connector though, how long the trs connector female plug going to lose the grip
moon audio use this connector, looks great but that connector really pricey
Shane D
It looks good. I would probably go with whatever is stronger. I would only use the Grado's at home with my DAP.
PhenixS1970
Haven’t heard any GS series (did listen to the ps2000e at home....amazing but way too expensive here). If it takes the qualities of the GH2 to the next level I’ll be very happy
