vinekly
- Nov 23, 2016
https://www.stereophile.com/content/grado-hp-1-headphones-page-3
Some excerpts:
Joe Grado's goal was to build a portable amplifier for the field recording engineer, and using a battery supply kept the size and cost within reason. His amplifier performs far better than I would ever expect, and easily outperforms any headphone jack I've encountered on tape recorders, CD players, and preamps. But I'd like to see someone manufacture a no-holds-barred, AC-powered headphone amp, which I believe is necessary if the full potential of high-performances headset such as the HP 1s is to be realized.
The Stax Lambda Pros are excellent headphones, but I believe that their performance is compromised by the dated Stax electronics. Although the Lambda Pros certainly deserve a Class A rating as headphones, the associated solid-state electronics fall far below that point. [The Stax Lambda Pro tube amplifier should be regarded as mandatory to drive these headphones.—Ed.] In fact, I wouldn't rate the ED-1 equalizer or the SRM-1 Mk.II amplifier higher than Class C, with the amplifier toward the high end of that category, since I believe it fares a bit better than the equalizer. Given a choice between the Stax Lambda Pro/SRM-1 Mk.II/ED-1 as a headphone system, and the Grado HP 1 with a high-performance amplifier, I would have to opt for the Grados primarily because of their lower sonic coloration, slightly more extended bass, more spacious sound, and superior dynamics. The virtues of the Grado system, for me, outweigh the slight improvement in detail and high-frequency extension offered by the Lambda Pros. In fact, the superb detail and extended highs of the Stax headphones only magnify the deficiencies in the electronics. If the Stax were powered by electronics worthy of a Class A rating, it might be a different matter.
Read more at https://www.stereophile.com/content/grado-hp-1-headphones-page-3#8ZwKE8FtyhqY4GOy.99
