wormsdriver
^^If you can get a replacement, yes!
+1^^If you can get a replacement, yes!
Thanksif i remember correctly, from their non-i generation, they already used UHPLC on their voice coils started from their mid range models which is i think start from sr225 or sr325
While I don't have an LG-V20 or an Rs2e for that matter. I truly believe you'll be fine if Grado ends up being to your liking. I use my Samsung S7 phone which is NOT great and it'll still sound good with Grados or similar low impedance cans that I have.Hi folks,
Just wanted to know if anybody has an opinion about Grado headphones paired with the LG V20 phone. I have an opportunity to buy a like-new RS2e. I know it's a matter of opinion but I'm curious about the V20-RS2e match. I mostly listen to jazz, rock, punk, indie music. Would it sound dull without an amp? Thanks!
I need to pick some brains again! I've been looking at getting a pair of Alessandro MS-1e's to have a listen. They can obviously be picked up quite cheap, and I've got plenty of spare pads I can mess around with now.
Any of you guys had any experience with them? I've read the MS-1 appreciation thread, but details get a bit thin on the ground with the newer version. Any help would be appreciated.
I have Alessandro MS1e, although I purposely bought them with the older, shallower cups because I wanted the most portable Grado headphone possible (not counting the eGrado, which I have but had to send in for repair and just gave up on after the right driver again began rattling on lower frequencies shortly after the repair).
I unfortunately have never heard the GH2 so I can't offer any comparison between the two, and I no longer have any other e-series Grado's to compare with, either, but I find they have the classic Grado SR series sound I really like, not actually too different from my Alessandro MS2i (which are more resolving to my ears), not as bright as my goldie SR-325i.
The gap might stay the same, but Grado is very good when it comes to this sort of thing, and being that the Gh2 is still a relatively new headphone I am sure they.would replace that cup for you. I don't know how good the Grado dealers over the pond are thoughThanks guys, I'll get in touch with the seller. It's only an issue in that I can't see how far down the cup beyond the grille the crack goes. It's not huge in terms of a gap, but it's just... meh. I don't know how likely it is that it would get any worse?
RS2eOK, so I can return these now. I'll start the ball rolling on that.
Just to satisfy a curiosity (and because I'm an idiot...), what would be the main sonic difference between the GH2 and the the RH2e? I know that they get a lot of love on here. Any thoughts?
Cheers!
I'm also curious how the GH2 differs from the RS2ERS2e
