Yup, I only use the generic G-pads since the OEM G-pads are a bit harder on the edge and kill the bass. But its the opposite when it comes to the sound with the L-pads where I like the sound of the OEM L-pads much better than the Earzonk or generic ones. I have a prototype Nhoord driver that was designed for use with OEM G-pads and while it does sound quite good I still like the softness of the generic G-pad better.
Grado Fan Club!
- Thread starter Vikingatheart
- Tags
- 1000hours burn-in minimum 1000hours hearing damage minimum dynamat grado grado hf3 grado-gs1000 grado-head-fi-series-hf-2-headphones grado-igrado-black grado-professional-series-ps500-headphones grado-rs1i-reference-series-headphones grado-sr-80 grado-sr125i-headphones grado-sr225i-headphones grado-sr325is-headphones grado-sr80i-headphones grado-statement-series-gs1000i-headphones nhoord nhoord red v2
aristos_achaion
- Apr 19, 2009
(never mind)
lugnut
- Sep 28, 2009
Have you had a chance to hear the GH2 or PS500E with the G pads. I am looking for a Grado that is in production that sounds good with G pads.The only Grado that improves with the use of the G pads, and it is a great one, is the GH1. In general, putting G Cush on an on-ear Grado degrades sound quality. (The GH1, in my preference, is second only to the RS2e among the Grado on-ears)..
ruthieandjohn
Stumbling towards enlightenment
(Formerly known as kayandjohn.)
I have tried the PS500 (not e) with and without G pads... results are in my "comparison of (nearly) every Grado" thread linked in my signature... changes the sound, improving some aspects and degrading others, for no overall gain. I have not tried on the GH2 (don't have 'em), but have not heard from multiple people that the G improves the GH2 as I have (and found, and compared first hand) on the GH1.
Stevenpi1992
Hey guys, I have what may be an odd question. Would it be worth it to upgrade from the SR80e to an older 'i' model? For example, SR80e to RS2i. Or would it make more sense to put away more for the newer RS2e? Im fairly new to Grado's but am in love with their sound so any advice would be great. Thanks!
I'm new to Grado's too, but I think that would be more of a sidegrade if anything. Whether that's worth is up to you, but probably not subjectively speaking
Sherwood
I don't find the "e" models to be an across-the-board improvement, so I'd encourage you to go for it if you're curious.
It really depends on what you are looking for, I like the "e" series due to the warmer tuning and not looking for traditional Grado soundHey guys, I have what may be an odd question. Would it be worth it to upgrade from the SR80e to an older 'i' model? For example, SR80e to RS2i. Or would it make more sense to put away more for the newer RS2e? Im fairly new to Grado's but am in love with their sound so any advice would be great. Thanks!
ruthieandjohn
@Stevenpi1992 , it very much depends from Which and to which model you are going.
For example, in my opinion from owning all and comparing, RS2e > RS2i > RS2, but RS1 > RS1i > RS1e. In the first case, the -e version is the best, but in the second case, it is the original version that is the best. I do think that RS2i > SR80e.
Stevenpi1992
Thanks for the information guys! And @ruthieandjohn , I just noticed the comparison link in your sig. I'll be taking a long look at that as well
What year did the 325is come out?
I can't find the year of the release, and I own them. I think it was '11-'12 but I'm not sure?
Thanks
Thanks
ruhenheiM
- Dec 27, 2010
i think it should be when grado released second generation which according to their website it was around 2007
http://www.gradolabs.com/company/timeline
yeah.i think it's around that.i found a what's hifi reviewed 325is in 2008
https://www.whathifi.com/grado/sr325is/review
I read this as well as many others with varying dates, and probably found all the same reviews/Info as you have, but can't seem to find out when they transitioned from the (i) to the (is) series?i think it should be around grado released second generation which according to their website it was around 2007
Thanks
ruhenheiM
- Dec 27, 2010
the transitioned time probably really hard to trace because as you know grado never actually tell when they deploy it,they just label it as it is.but the second generation.the i.that's quite different matter because the chasis/headphone cup actually changed.from non i to i version.from flat to have mushroom shape. when grado released ps1000 i remembered they already discontinued the sr325i which if i'm not mistaken the sr325i was the gold version. i don't think there were any sr325 with gold cup. when they released the second generation.they put letter i on all their headphone.but the sr325 already have letter i(for the gold one).that's why they called their second generation of sr325 as sr325is and just rolled back the colour to silver.. in alessandro lines up of the ms2.just ms2,ms2i,ms2e.there is no ms2is. perhaps the weirdest part of sr325is is the colour scheme.i remember back then they have a few iteration of silver finishing because of the problematic of some finishing not always resulted a consistent finish
but i'm not really sure about this one though
maddin
- Dec 13, 2008
@ joseph69:
this is probably difficult to find out. I bought my first Grado the SR80 (without i) in spring 2008. Than in summer I was in full grip of the grado fever and bought my golden SR325i. I had than never heard about the new series. Ok here in Europe we might be a bit behind in the model changes but still I would say this happened later. It must be somewhere here on the forum because I remember people posting pictures of the SR XXi models with the change plastic cups. At that time there was no official note from Grado....
