hakuzen
- Feb 9, 2016
@CoiL , you could use 8, 10, 12kHz or even higher resonances, but the mics you are using are reliable till 10kHz (and this going high). a decent chinese true precision 1/2" mic, reliable till 10kHz (in theory), use to cost around $90. till 16kHz, ~$135. till 20kHz, >$200.
it was just a tip for people using tubes, to get an idea of an approximated length of the tube.
there are some iems where you can't find 8kHz peak. i use to check 6, 8, 10, and 12kHz resonances (one of them will be present for sure). but sometimes, you can't center any of them by modifying insertion depth (which is limited) in a 711 coupler.
in these cases (and in the cases that adjusted insertion depth is completely unrealistic), i simply use the depth i'd use in my ears, approximately.
so trying to balance an arbitrary norm with realism and common sense. this is a hit and miss game..
you are right. different iem are built different way: longer wide nozzles vs short narrow ones, different tuning, etc. and the length of the tips you are using also alter the distances, like you and castleofargh have told.Like I said earlier, I think shooting for an 8 kHz resonance peak is a really bad idea. If you create graphs this way, you could make two dissimilar IEMs look to have similar treble performance. That's just misleading.
And what are you going to do with the Zero Audio Carbo Tenores? Which peak are you going to move to 8 kHz??
This would only makes sense if you carefully adjust the insertion depth (with extra-length eartips) for each and every IEM you listen to, in order to make sure you always hear a peak at 8 kHz. And if you do that, you're nuts. IMHO.
