hakuzen
- Feb 9, 2016
thanks for the heads up!sort of global response: we have to determine what we're trying to achieve. best measurements or sort of realistic measurement? because holding the IEM in place is something that doesn't necessarily happens in our ears even when the shell is securely fit on part of the pinna and ear canal, all that stuff is flexible.
same for the idea of not using tips. for anybody who needs to make repeated measurements that must achieve the same response, obviously getting rid of the tips is the best approach. Etymotic has a sort of mold where they insert the IEM without tips to measure and match the pairs of the er4 series, and probably to test a lot of stuff on the other models. but the reliable, highly repeatable response we get is not what an actual ear will get. and that to me is a problem. I'm well aware that even the IEC standards are in the end practical choices, some even suspiciously arbitrary IMO, but at least those are references that most people have learned to interpret subjectively(with more or less accuracy). I personally feel that there is value in all those years of habits. if a new better standard comes along and is accessible to us amateur nerds, I'm up for it, but it needs to be something accepted by most people, or we need to have such a massive output of measurements that we can become our own reference, like Tyll did with innerfidelity, like crinacle is doing right now. we accept that their measurements might not mean much in term of standard, but they provide big enough samples of measurements for us to get the relevant relative variations compared to some IEM we have used ourselves.
@hakuzen the most successful changes for me in term of vibration:
- delay the measurement by 2 or 3 seconds in REW, click and move away. or put the mouse on a different desk and stay away ^_^
- measure from 10 or 15Hz instead of 20Hz. I still only look at and show from 20 to 20K, but sometimes it avoids some wiggly artifacts in the subs. no idea if that's due to my gears or if it's something that sometimes happens in REW? same thing with measuring impedance, on rare occasion the impedance curve takes a dive in the upper range, and if I do it again, it rises(if BA), or does whatever it's supposed to measure. I don't seem to be changing anything, so I assume it could be REW. I remember seeing Purrin show such an impedance response that wasn't right in the treble, so I assume it might happen to others too. for that beyond doing several measurements, I'm not sure how to avoid it from happening(but it's super rare for me anyway).
- using a fanless computer. I only do it when I'm really looking for something super specific, because the fanless one I have was crap when it was new, and that was years ago^_^. it's just so slow I go mad from using it. so I usually measure with my rather noisy but responsive one as for FR at least, it's irrelevant so long as I measure a signal in the 80-90dB SPL. but for distortions, in my case it changes everything. I've done stuff to reduce the noise coming from my regular computer too, with yoga brick, acoustic panels, pillows, etc, but none of that can stop low frequencies. so to my ears it's pretty quiet, but my mics disagree ^_^.
- electrical pollution. some gears are just more sensitive than others, but it seems pretty common to have some little 50 or 60Hz noise, or other stuff when some equipment is running in the house. my personal nemesis is my fridge. if it starts running while I measure stuff, noise and distortion levels increase instantly.
- in the dead of the night is always where I got my cleanest measurements, because people sleep. even from an electrical point of view things are just better for me usually after 1AM. again, that doesn't matter for FR, only for stuff measured some 40dB below signal and lower.
- try to feed the mic with different sources. when I started this, I was always feeding my Vibro Veritas with a really noisy and crappy soundcard from my laptop, and it's only when I got other mics requiring different sources/plugs, that I realized how crappy the laptop's DC powering the mics really was. I made an adapter to still be able to use most stuff from the laptop, and that was my wake up call. virtually anything was cleaner, my tablet, phone, some batteries, they all were a lot cleaner. now I mostly use a mic that requires 48V of phantom power, so I don't really have a choice. but for the dayton it might be worth trying a few devices just in case.
well I guess we could also just have proper gears and clean quiet room, but I at least will never have that.
last version of REW uses a new way to show noise before and while measuring, more graphical. now you can see clearly the impact of mouse clicking, pc fan, your movement, neighbors or street noise, etc.
i already use a 3 seconds delay, and even hold my breath while measuring, lol.
do measure from 0 to 96kHz as a rule (think is better for impulse response calculations, and don't want to redo measurements to check behavior till 48kHz; all gear calibrated for that resolution, of course).
for impedance measuring, found that is mandatory calibrating impedance before measuring, always you try a new iem.
the fans from my pc are quality low noise fans (!beQuiet), but still noisy when they activate while measuring. purchased a mini pc at 3.28 for multimedia (including measuring audio) purposes, although it has a 8cm fan. and i've not mounted yet an ultra silence desktop pc (big fans, acoustic isolation panels), which will be on the floor rather than on the desk. so i hope to get a big improvement soon.
trying to measure at night. during the day, buses, traffic, neighbors, and two schools just in front of my home, create excessive noise and vibrations.
my measuring mic also gets feed with 48V phantom power, from creative EMU-0404, which features ground lift and it's fed by a quality low noise usb feeder through isolated canare cable + quality plug. amplifier used is JDSLabs C5D, low noise, distortion, and impedance, fed by internal battery when measuring. i have to locate sources of electrical pollution. already have to mount an EMI filter i purchased to reduce high frequencies noise and stabilize the AC (i have to add some plugs and make the connections, including modification of the power strip current take), to feed all gear (pc, usb feeder, etc.).
another good way to decrease noise while measuring, is using 2 sweeps of 2M in REW. slower, and ram consuming, but it works very well for definitive measurements.
my recent main problem is the noise and lows distortion created by the press touching the iem. i wouldn't mind if the tips slide off a bit and stay in the coupler, but they get out completely, so using the press is mandatory for those tips, although it barely touch the iem, making minimum pressure (it's just a top limit).
i've added soborthane feet to the press, and replaced the end rubber which touch the iem with a smaller one, naked (no putty nor soborthane), a few hours ago; the improvement has been great.
but the difference is still noticeable: from -80 to -60dbFS when not using the press, to -50 to -40dBFS. from zero extra lows distortion, to some extra distortion below 40Hz (0.5% to 1.5% = 10dB, in flc8s).
i'm satisfied with last improvement. to generate distortion curve, i'll use the self-staying tip which measures nearer to stock or reference tip. for frequency response, these new numbers allow a smooth raw curve when using the press.
