MattTCG
- Jan 22, 2012
Just curious but what volume level do you listen at? I'm usually between 24-32.
Quote:Just as a dac for your laptop? Just curious
Just got an old Netbook. Pretty sure I will use the amp portion also
Yep just as a DAC. The E9 just acts as a LOD for the E17.
E17 has a pretty decent DAC built in and i'm too poor to afford anything higher...but i'm happy with what i have (for now).
so that's all the E9 is doing? LOD? I was about to say omg, is the E17 just acting as a "cable" between your source and the EF5, but then I just found out that the EF5 is an amplifier
I don't know if you guys remember me mentioning before, but i had that problem where playing music through youtube resulted in static/popping sounds, but using foobar or any other music player works fine.
Well that was on Windows 7, trying the E17 on Linux Mint and i get no such popping sounds on youtube or with the built in music player.
I thought before that it might be my usb port but this sort of debunks that. I don't know what to do to get this working right on windows. Could it be bad drivers?
Possibly a dumb question... If I wanted to could I use L7 to go Laptop--->E17--->Stereo amplifier---->Speakers?
Not sure if the LO signal from the E17 would be suitable for that type of amplifier...
Cheers Bowie. I knew I could make the physical connections just wasn't sure if it would actually work properly though.
The worst thing about my E17 so far...I don't want to use my clip +. Listening almost entirely at my PC at the moment.
Need to do more listening with E17 amping Clip + but initial thoughts are it doesn't add much apart from volume.
