- Jan 29, 2010
Very nice!
HI. It's just glossy varnish with 400 grit sanding between the layers. After the last coat of varnish is completely hardened, it has been polished with furniture polish.
Capacitor Update time.
First off,
Russian Teflon K72P6, used to bypass the 2.2uf film cap which was itself used as a bypass on the last 220uf electrolytic in the Crack power supply.
K72P6 Impressions with just over 200hrs on the clock.
I have noticed a slight change in sonics to the top end, it is very subtle but smoother, with what I can only describe as an easiness in its smoothness. Less grain and better resolution but without any hint of the normally associated brightness that I have experience before with such resolution. Its not a wow instantly noticeable sonic signature instead it just blends in as part of the whole picture bringing a touch of refinement. It kind of needs to be listen for specifically in order to get a handle just what has changed. But does come across in the whole.
I would like to say I have no plans to remove the Teflon as I am really loving the sound coming from my Crack at the moment it is absolutely sublime with the T1's and its with some trepidation and no doubt a good dose of stupidity I am going to continue swapping capacitor types and positions in a vain attempt to get a grasp of some of the character the different capacitors types can impart.
Whether or not the changes might improve, on what I currently think could well be perfection for me is yet to be discovered.
So my Crack cap rolling odyssey continues.
This time its the turn of a pair of Jantzen z- superior's, experimenting with them used as bypass caps for the JFX 100uf films and later in combinations with some pio film's (polypropylene film in oil, not paper) and some Hybrid mylar, paper and aluminium film in oil variants.
Back to the Jantzen who interestingly state their Z caps require no burn in.
From the Jantzen website
"Superior Cap Even the finest nuances can be heard.The sound never gets over-edged, really superb naturalness with a somewhat bright top-end. Jantzen Audio Superior Z-Caps are absolutely high-end components, delivering a natural, almost holographic sound stage. Even the finest nuances can be heard."
I am pleased to say this is very much inline with my own impressions the difference over the JFX alone is instantly quite noticeable. I am wondering if the "somewhat bright top-end" will settle down at all. And while its not " over-edged" it is walking a fine line with T1's and the accentuation of sibilance on some tracks I find just a tad to much for my personal taste. So I hope this might calm down with a little time on the clock.
Everything else is just dandy I particularly like the effect the Jantzen has with the bass it seams more expansive and deeper. There is some really nice ambiance coming through on live recordings
Following on it does suit the HD650's rather well also.
Holy cow, Jamie! Nicely done!
You're becoming our resident cap aficionado!
I don't want to go through all 250+ pages ..what's consider the easiest -best re-cap on this unit that improves sound quality and where i can get socket replacement for 6SN7 ?
Thank you
Any decent pair of 100uf 250v+ film caps should do. Just be attentive to size if you don't want to have to put your crack on risers.
Well, despite my 'complete satisfaction', I saw a cheap Mullard ECC82 on eBay and it arrived yesterday, my first upgrade from stock Crack and I was surprised that tube rolling has an effect, even at that price (tenner or so). I definitely prefer it to the stock tube, just a little tighter in the bass but also the top end has opened up, separation is better with drum sounds. Something like Contact off the recent Daft Punk album sounds like your head is taking off, makes me sit up straight. Thank God I've only seen the 5998s available in pairs, that should put me off for another six months or so.
