leo5111
- Sep 5, 2005
i tried all usb ports NOTHING but weirdest thing changing extension from .Flac to .Fla with .Fla it shows up and plays
that's really odd. Ill try it again.i tried all usb ports NOTHING but weirdest thing changing extension from .Flac to .Fla with .Fla it shows up and plays
The manual says:
"- The maximum number of files and folders that can be recognized
by the product:
12,000 (Built-in : 8,000 files + 4,000 folders)
24,000 (microSD : 16,000 files + 8,000 folders)"
I'm definitely under the limit, there are more files in the built-in than in the card.. hmmmm
does this apply to the internal storage as well? if so i will try it
just re-updated to latest firmware still NOTHING flac does not show
You downloaded the file again or just copy the file that you already had in cumputador to the internal memory of Plenue D?
