Cowon Plenue D
Discussion in 'Portable Source Gear' started by aerosatan, Nov 30, 2015.
216 217 218 219 220 221 222 223 224 225
227 228 229 230 231 232 233 234 235 236
  1. Hi-Fi'er
    Load defaults : Reset all settings to the default. See if that does anything. If not try this: press and hold the volume + and − buttons to reset for 6 seconds or more. If that does not help, then yes, reformat the card.
  2. leo5111
    doesnt matter ANYTHING i have flac wont show another member even sent me a test flac that plays in their system
  3. Hi-Fi'er
    @Leo. Can you upload one of your FLAC files to google drive and send me the link so I can review your file? I already understand your issue. No need to re-explain it again as you already explained it and it's very clear.
  4. leo5111
    is there a specific way to format internal storage? if so how and using what? thanks
  5. audio123
  6. Hi-Fi'er
    Once connected to the PC, you can see the drive in the Windows Explorer, you can right click and reformat. I don't think that is your issue though. I would try as last resort. I think your Firmware is messed up. Is this a new unit?
  7. leo5111
    allready did im going to try 1.13 and see what that does
  8. audio123
  9. leo5111
    i tried 1.14b1 and 1.13 NOTHING and when i choose reset to defaults my volume is still set up to 90, like it was before i would think it would reset that if i need to fomat the internal what are the specs i need to format it to? i tried holding volume up and down and after 6 seconds it just turns off and when i turn it back on it seems like nothing changed
  10. Hi-Fi'er
    If you reset it, nothing will look different. But all the setting are restored to factory if you go check.
    As for formatting:
    Issue: After formatting the product on my PC, it can no longer be read by my PC, the memory has been reduced, or the file transfer rate is slower etc.
    Solution: The built-in memory of the product is already formatted and does not require additional formatting. For proper file transfer speeds, the PLENUE D’s internal storage and any external microSD cards (32GB or less) must be formatted as an FAT32 file system with an allocation unit size of 32 KB using Windows 7 or later. Large-capacity microSD cards (64GB or more) must be formatted using an FAT32 formatting tool (e.g. guiformat) to be properly recognized. (32KB allocation unit size is recommended.) This product does not support the format of MAC OS.
  11. leo5111
    by 32 they mean 32768? gui format lists 512.1024.2048,4096,8192,32768,65536
  12. Hi-Fi'er
    Yes. But on the SD card you can do 4096 that's what your average hard drive does and its the best balance of speed and power usage based on the files we place on our players
  13. leo5111
    i did 32768 on internal and 4096 on sd card
  14. Hi-Fi'er
    Good. If that was the problem, it should fix it hopefully.
  15. leo5111
    still NOTHING but oddly if i change file extension to .FLA and it see,s and plays em maybe ill just do that...lol is there a way to mass re-name the file extension?...lol
