Cowon Plenue D
Aug 17, 2016 at 6:09 PM Post #3,229 of 4,949
I wouldn't be too alarmed. AMP3 reguarly run out of stock. They don't seem to buy in heavy bulk
Aug 17, 2016 at 7:08 PM Post #3,230 of 4,949
Hi all.
I got my D for some months now and a 128Gb microSD Kingston sdxc class 10 last friday.
Lil question here: is it normal D taking 25/30 seconds for database update when turned on? is it too much time?
I know the player needs time to pre-load all library on internal memory and the card (none full).. but wishing it could be a little faster. maybe I messed up card's speed somehow... any lights?
1.14 firmware here. Thank you!
Aug 17, 2016 at 7:24 PM Post #3,231 of 4,949
Hi all.
If you activate the sleep mode the Plenue D turn faster on.
You formatted the micro Sd card before using? It is always good format (FAT32).
Aug 17, 2016 at 8:33 PM Post #3,232 of 4,949
Yup. Fat32, 4096 b, but was not recogd by my old win vista at first.
Tried to format using guiformat, but showing only 22Gb. So I tried to format it by win explorer and cancelled it (still showing 22Gb only). Then I saw here in this thread about a driver or something for vista and downloaded it. guiformat again and success on that.
anyway, if the device is turned off, the time for database update is good then?
I remember that fw 1.13 was always ready to flow, but I had no SD on second thought.
Thanks again!
Aug 17, 2016 at 9:32 PM Post #3,233 of 4,949
Thanks again!
Exact. When activate the sleep mode, it will turn faster. Just go to Settings> System> Sleep Mode.
Aug 18, 2016 at 8:05 AM Post #3,236 of 4,949
please help
i was try reset my plenue D (hold volume buttton + and -) not effective and my plenue D screen still cannot use
i try to format my plenue D
thanks
Hey maybe you can try holding Power button down while holding both volume buttons? I haven't tried in my Plenue D unit yet, but this works in all other Cowon products ive seen till date. Maybe it works.
Aug 18, 2016 at 10:08 AM Post #3,238 of 4,949
i ordered mine this morning off EBAY IF they are on the ball will ship today and come tomorrow because i am like 65 miles from them and Fedex or Ups ground like 100 miles or less is 1 day transit
Aug 18, 2016 at 11:14 AM Post #3,240 of 4,949
please help
thanks
The manual says: "If the buttons or touch screen do not respond during use, press and hold the volume + and − buttons to reset for 6 seconds or more."
If you format the player, format FAT32 and then copy the firmware files (like installing a new one) for the system to come back.
Note: After formatting not disconnect the player, copy the firmware files first.
