- Aug 9, 2006
I don't find interface speed to be improved from 1.10 but any stability or file read compatibility upgrade I welcome with open arms.
Wondering how is the sound quality of this Compared to X5II ??
On my Plenue D the new FW 1.11 fixed a slight glitch that kind of annoyed me and maybe my brain may have tuned into it so it may have been more noticeable to me than others or just a difference from unit to unit!
But when playing MP3 files from the internal memory, there was a very slight high pitched noise, lasting for 1/10 of a second or so between songs.
I believe it may be related to to some kind of processor buffering issue. Anyway, the FW 1.11 seems to have fixed this issue on my Plenue D, certainly not there anymore, first thing I checked for! So maybe gapless playback with the new FW may have improved overall for all units using various formats?
Touch screen navigation seems fairly similar to me at least and since I didn't have any issue with this beforehand I most likely wouldn't notice any kind of significant improvement.
Change in sound stage. Did anyone have any kind of DSP effect on when they changed FW? Because this is where I could buy into experience a change that wasn't purely coming from my brain/expectation. When JetEffect set at normal I didn't experience any alteration.
Very good question.At times I am liking the PD more than other times I am liking the P1 more. I will say the P1 will add a slightly wider sound stage.
Has more eq features and a bit more power.how bout the differences between jeteffect5 and jeteffect7 and sound tuning
also power wise?
What is the best way to format a micro sd card to FAT32? I see the guiformat recommendation in the manual, but when I google it looks like a hornet's nest of options. I saw a detailed, step-by-step approach in a previous post here but going back I can't locate it. Much appreciated.
P.s. loving the sound on this thing. UI aint bad. Recognizes all my tags too.
Beauty case. How's it flap closed? Magnets?
