Depends on the sound you're looking for. Also, the budget.
I'm recommending the FAD Heaven 2 at ~$70 and the MEElectronics A151P Gen. 2 at $50. Both are excellent mid-centric BA IEMs (although when you think about it, most BA IEMs are mid-centric anyway).
Thanks. I've heard A63's are absolutely fantastic for vocals. But i also learnt that they are a bit weak on the bass dept. Im not a basshead by any means, but i would luv a bit of sub bass rumble when the track calls for it. Can any one 'who owns it confirm about the A63 bass?
Yes, i see they are good too, but its around $65 and im actually waiting for a price drop on those Either that or the KC06. But then, I still cant make up my mind if its a better upgrade to T1-E.
Monoprice for 8$ is imho crazy good but the fit could be a problem for some unless some filling is done to the sharp edges and cable noise too...sound wise me like very much...to me they don't have any business to sound that good for it's price....balanced they are to me...with good bass while Moxpad X3 world be more suited for EDM genre as they are bass cannon and clarity for me are not quite on point...bearing that...they are good for it bcuz the built quality and the cable with mic function....anyhow they do pair well with me Xioami phone for music as the sound from me phone are pretty thin sounding with decent detail...so X3 is good in that sense....unless your dap or source player is warm sounding...don't think they will go well....
I'd recommend Zero Audio Tenores. Vocals are beautiful on Tenores, they sound more balanced than V-shaped TTPODs and they also have nice sub bass. Not overwhelming but easily enough. I am a mild basshead and Tenore does a good job of keeping me entertained. Add into that awesome instrument separation and positioning, Tenores are an upgrade over T1E, I'd say. Though the difference is not much tbh. They are fragile though and may not be able to take abuse like T1Es.
Is it?. Woah u have rated Tenores higher than B3pro1, they must be that good then.. Build qualitys is not really a problem for me (as long as its nothing internal like cable short/ dead driver etc) as i handle my IEM's with care. Well, i think i'll zero in on the tenores. tnks a lot
Its my personal preference, friend... I've mentioned that there. Like I said I am a mild basshead and so Havis don't hit the sweet spot.
But they are REALLY good. You might have read around, they excel at positioning and soundstage. Their sound is very neutral and very enjoyable for certain genres. It's a keeper too.
If you like neutral, more true sound then I'd have specifically recommended the Havi but since you had mentioned that you need some sub bass, Tenore are the way to go. Sub bass is enough and nicely layered in it.
Count me in! I enjoy the T1-E more than the Tenore as far as sound sig goes, even if the Tenore is slightly more refined/technical in some areas(like the treble refinement, timbre, and microdetails) to my ears. I'd say Duoza > T1-E >= Tenore for me.
They are all great, but T1-E is epic. Best combination of bass and Mids out of the three, and the treble is nice, not too harsh and just right IMHO. If the treble was a little more detailed and separation was a touch better it would be my #1.
