It should. On that note the battery life on this device is incredible. I'm getting over 13 hours/charge on high gain playing flacs and DSDs (with minimal screen time).
Awesome.
Thanks for this! I was shocked this morning to find that my N6ii battery had drained from 95% to 55% overnight with airplane mode on. When I looked at the battery usage, sure enough, it is google play services that had drained my battery while running in the background. I just enabled all permissions for this app, and toggled the setting under battery usage that is supposed to limit the apps background activity while not in use. Hopefully this does the trick!
How do you find the combo with meze rai penta? eager to find it... along with the combo campfire solaris.
Yesif i buy the n6ii from hong kong can i have it with an english interface, and google play store
Fw10000.anyone try pairing with jvc fw10000 or Campfire Solaris? Wondering which one would be good pairing with Cayin
did u try aaw canary, khan, jomo trinity brass, tia fourte, 64audio u18t and did any of these impress uFw10000.
Try all 3 shops. Each of those iems have pros and cons. Most likely no jvcs in stock.did u try aaw canary, khan, jomo trinity brass, tia fourte, 64audio u18t and did any of these impress u
also which store in hong kong gives best discount ( DMA, Jaben, Lets go audio )
Actually as of last weekend I saw DMA at Wanchai having the JVC FW10000 in stock, and there are actually a couple floating around on the used market here in HK as well.Try all 3 shops. Each of those iems have pros and cons. Most likely no jvcs in stock.
