Well, it's been almost a month and I've increased my budget to ~$400. Wondering if the ALO Pan Am is worth the extra $200 w/ passport. Maybe I'll settle for a WA3+ or Schiit Lyr.
Another option for you, and update on my previous experience with Asgard 2.
I ended up returning my A2 (first revision) due to harsh sounding mids, transformer hum, and high noise with low impedance headphones (I think all of these issues seemed to be resolved in the latest, second revision of A2 - only I I decided not to wait for it back then).
I replaced A2 with Graham Slee Novo (that's, of course, at a different price level). Novo was quite an improvement - very transparent at mids/highs, and no harshness of any kind (after thorough burn-in for a few weeks).
As a matter of fact, Novo seemed to be even more transparent than my other Musical Fidelity M1HPA and even Beyerdynamic A1, although I did not buy it to try to compete with these amps. As DT990 has good bass, Novo has very good synergy with it as by itself it provides less bass than M1HPA or Beyerdynamic A1 (and I personally don't like DT990 with either of them due to this fact).
I use Graham Slee Novo in a simple, portable (as in "with a laptop") system with new Meridian Explorer (line out only), Wireworld Starlight 7 USB cable, and Cardas iLink mini to RCA interconnect.
The sound this "portable" system provides with DT990/600 is truly amazing, and it is not very far from my main system costing way, way more - although nothing really crazy, of course (Wireworld Starlight 7 USB/Musical Fidelity V-LINK192/Kimber Kable AGDL silver digital/Arcam rDAC (coax)/Cardas Quadlink 5-C/Beyerdynamic A1/Beyerdynamic T90).
I used to have trouble listening to DT990 after I bought T90, but not anymore - I really like DT990 sound with the above system and can easily switch from the main one to the "portable" one (and do this often) with no loss in music enjoyment.
So if your budget allows for it, I would highly recommend trying Graham Slee Novo with Kimber Kable (at least Timbre or Hero) or mid-level Cardas interconnects.
