Yo Travis,
I disagree with his point about resonance, but the Q701 and K702 both have funky mids. The mids are recessed on both models to a degree, but the Q701 doesn't have the recession that badly. I don't have any issues with the treble of either of them though. I find the treble of both to be bright but not harsh or strident.
The foam in the K701 and K601 is of the same material. You can easily obtain it from AKG directly if you contact them. The K601, K701, K702, and Q701 have the same part number for the foam. Now you should try some foam from the K240 as it's different and does make the sound warmer. You might like it a lot.
This is actually wrong. I know because I looked this up a long time ago and posted part numbers in this thread.
K701 and K601 have the same part #. They're softer, smoother and have more holes in them.
The K702 and Q701 have the same part #, different than the above. They're more sparkly and more scratchy.
Are they the same, but with different part #s? Possibly, but they look totally different. Here's more info:
http://www.head-fi.org/t/564427/k701-vs-k702-vs-q701-which-one-considering-recabling-among-other-things/15#post_7755190
The Q701 foam does make the Q701 sound a bit different than when using the K701 foam. You can verify this when playing anything with ear piercing treble. Q701 foam takes the edge off. Smooths it a bit. Less clear sounding, but not enough for me to care.
I most definitely did feel that the K702 had rather thin mids and almost recessed sounding (except for it's upper mids).
My Q701 definitely has no part of it's mid-range recessed. Vocals are not ever shoved back a tad like on my old K702. Actually, the Q701 doesn't have the up-front mids of my other headphones, but more accurate than the K702.
Here's the part #s I found from another thread:
K701/K601
2458Z5801
Q701
2458Z58010
Could be really just variations in foam and all the same. I doubt it though. You can easily hear the difference. Hard to believe I know. Just have to know what to look for or else it's harder.
