XTF1
- Nov 9, 2014
Here it the link: https://www.aliexpress.us/item/3256...00030673269606!sea&curPageLogUid=hqhH74ueT0lTNo fun without a link.
Also sold in other stores.
Because of the wording in the information it's highly unlikely people will find (via a search) and buy this model anytime soon...Here it the link: https://www.aliexpress.us/item/3256804649334862.html?spm=a2g0o.productlist.0.0.2dfc7b30Dv1Eb0&algo_pvid=d1de5269-e88a-48fd-a6bb-829579599f5f&algo_exp_id=d1de5269-e88a-48fd-a6bb-829579599f5f-21&pdp_ext_f={"sku_id":"12000030673269606"}&pdp_npi=2@dis!USD!122.0!61.0!!!!!@2101e9d316681879308127736e4e3a!12000030673269606!sea&curPageLogUid=hqhH74ueT0lT
There's probably some pixel resolution limit. Find the JPG file for the songs that display correctly and redo the album art from those that don't with a similar resolution. I always use a program called EasyTag to work with embedding image files into the song files.Hello guys,
I finally ordered a Zishan Z4. I don’t know why but I love this little DAP (vintage/brutal design, very good sound, Bluetooth…)
However, it’s just a detail but I’ve a little issue with the album covers. I always put the picture for each file.
When I’m playing an album on the Zishan, I can see the cover for some albums but not for others. That’s strange because all the files are jpg. I tried to add the cover on each song but it doesn’t work. Do you have a remedy?
Thanks in advance for your help
Hi! Here works for every file, I have a 512gb memory full of FLACs.Hello guys,
I've had my Z4 since July 2021. Aside from testing a 512gb card I've barely touched it in months. Battery was dead so I charged it last night. Checked that it was full then went to bed. This morning I played a couple of tracks from the new Revolver mono album. No issues. Battery seems to be healthy. Hopefully yours is as well. Maybe you plugged it in the usb dac portHi guys. So I've got this device a couple of weeks already and I've been enjoying it since.
However, I've encountered a problem with its charging.
I left it charging for a while and the indicator light says that it is fully charged. But to my surprise when I wanted to start listening to it the battery is totally empty.
This already happened to me twice.
Any help would be appreciated.
So I changed the tags that was pre-tagged and it worked... Not sure which tag affects which. But not it's playing the files.Hi, quick question? Have any of you had problems playing a FLAC file? I have an album from Qobuz that is not entirely playing and the Z4 just freezes then restarts.
Files are 100-200MB 24bit96kHz files around 3-4min
