shinmolina
You can search for a similar battery at Aliexpress. Measure the one you have in your Z4 and check the dimensions before buying. I have found this one, check if it fits the Z4.I have a problem with my Z4.
My battery is melting, so I can't close the back any more.
Do you know where I can find a Nnew battery ?
You have to unsolder the one it has now and solder the new one to the pads on the PCB. Have you been using your Z4 a lot or for a long time or is it just bad luck that your battery is a spicy pillow? Just curious.
