Hi,
To me qobuz is the way to go.
The implementation of that service into UAPP is not the best I've seen though.
I think they offer 15 days free for you to try it.
Hi,
Anyone have experience with UAPP on the Nvidia Shield? Seems to work well and I'm happy I can access Qobuz through my TV by using it. But one problem. It looks like its converting everything into android: 48khz. I've turned on bit perfect but its still converting. Any idea how to remove that on the Shield? I thought the Shield could decode the high res stream.
Maybe I need a DAC? I probably won't go that extra step (although I do have a DX 300, but I don't think I want to have to attach that every time I play).
Does anyone know if there’s any way to adjust the sensitivity of switching between library tabs? Or…can anyone else sympathise? I frequently switch between tabs accidentally when scrolling up or down the grid view of albums…is it just me?
UAPP bypasses the Android processing, which I believe automatically resamples to 48K, so even switching off bit perfect should still avoid any resampling. On my Hidizs dongle, bit perfect off but also EQ off etc, I still see the native file resolution displayed on the dongle which probably confirms this.
Good morning, I can't play 32 bit 192 khz wavpack files on my Android smartphone with the USB Audio Player Pro app. On this site: https://www.extreamsd.com/index.php/products/usb-audio-player-pro it says that UAPP is able to play wavpack but in my case the app can't even see the files. I use UAPP on my galaxy s23 ultra with Ibasso DC06 PRO USB DAC.
