Apr 13, 2022 at 11:36 AM Post #5,431 of 6,402
Podziękowania dla @Davy Wentzler, który zwrócił uwagę, że protokół smb ma ograniczenia prędkości (około 5 do 6 MB/s), które utrudniają przesyłanie strumieniowe plików DSD. Wypróbowałem więc sposób UPnP, instalując Minimserver 2.1.2 na komputerze z systemem Windows, którego używam do przesyłania strumieniowego (Windows Media Player nie obsługuje plików dsf) i teraz wszystko wydaje się działać.
This is a kidding. I have samba server on my router with connected pendrive.
When i copying from my pc to it any files i have max. transfer of usb which is 10 MB/s.
I also doesn't have problems with playing dsd or 192khz files via wifi 5ghz.
Apr 13, 2022 at 4:01 PM Post #5,434 of 6,402
Smartphone with UAPP.
Ok, then your setting is a little different from mine, since I have also the usb connection with the DAC that could maybe be a neck-bottle together with smb. As I wrote before, I can play DSD files in my smartphone with UAPP too, and I can also play 192 Khz files (using Qobuz with UAPP) both in my smartphone and with the usb DAC.
Apr 13, 2022 at 5:13 PM Post #5,435 of 6,402
I'm using smartphone with Ifi zen dac connected via usb.
Apr 15, 2022 at 5:23 PM Post #5,440 of 6,402
UAPP virgin here.
My family all use LG phones with an identical google account. How many licenses do I need to purchase?
Is it possible to transfer UAPP to spare/new phone?
If I am not mistaken, as long as the same play store account is used, you can install it on multiple devices. I have it installed on 3 DAPS, a tablet and my cellphone and was only charged for my initial download.
Apr 22, 2022 at 12:02 PM Post #5,441 of 6,402
hi Question here, I'm using UAPP on LG v50 to play local files (44.1/16, 44.1/24, 48/24, 96/24, etc) with bit-perfect mode = On or When possible.
When someone messages me or when I go to android setting/sound/notification sound, I can still hear notification sounds mix together with music. (w/ all bit-rate listed above). Does it mean that I'm not in bit-perfect mode? Should bit-perfect mode be exclusive and android mixer should not mix other sounds with music? regards,
Apr 27, 2022 at 6:05 AM Post #5,443 of 6,402
Is it possible to assign an icon to a playlist in the Library -> Playlists? I assume it's possible since there's a default icon there.
I have not found how to do it, if it is possible... I think it's not possible.
May 6, 2022 at 7:34 PM Post #5,444 of 6,402
This is a bit weird, and they don't sound the same either, more so than both devices playing without any EQ. The curve with the bigger treble hump is an LG V30, the other one an LG V50. Similar circuit design and hardware etc. I've checked and double checked the EQ settings are the same, so how come they're not?
In other news, the V50 is a much better DAP than the 30 largely because its power amp is much more capable. You don't need to use the dummy infinite load trick as often, most of my phones just sound louder without that on the V50.
May 11, 2022 at 3:11 AM Post #5,445 of 6,402
Any idea if we'll be able to use this on the pixel 6 phones now that they've allowed some usb DACs to work? I downloaded the trial version of uapp yesterday and it recognises my Hiby FC3. I'm on the android beta program though. My Hiby DAC works with the Hiby music player and neutron.
