USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Feb 4, 2022 at 5:27 AM Post #5,342 of 6,188
I have become addicted to using EQ for every single headphone. The Toneboosters plugin is perfect so far. The lack of precise PEQ with Low and High shelf filters is lacking in many DAPs. Are there any DAPs that have perfect precise 10 Band EQ? I have been using Easyeffects EQ on PC and the Toneboosters plugin for UAPP on my Android. For my taste I would never consider buying another DAP unless it matches the PEQ flexibilities of UAPP.
Can anyone recommend me a DAP with very good PEQ?
How about running uapp on Android daps?
I do love this way, my ak sp1000 with uapp
Feb 4, 2022 at 7:28 AM Post #5,343 of 6,188
How did you install UAPP on an SP1000?
Feb 5, 2022 at 10:47 AM Post #5,344 of 6,188
Did you guys ever experienced sample rate showing on DAP screen stuck at 48.0 kHz even though playing 44.1 and 96 tracks? Not sure if it is a visual glitch or something wrong with UAPP decoding.
Feb 5, 2022 at 11:38 AM Post #5,345 of 6,188
Check if Over sampling was ON.
If it set to Off, freq of file and shown sample rate should be same
I come back old Fw then install Apk installer app on to the dap
Feb 6, 2022 at 11:20 PM Post #5,347 of 6,188
So, Can you play a compilation album with UAPP? What am I missing?
You can for sure, using Folder browsing mode.
Don't know how the Library reads and treats tags, for a compilation album.
Feb 7, 2022 at 7:57 AM Post #5,348 of 6,188
More details please. Which firmware and Apk installer app works? Do you have to stay on older firmware after installing?
Feb 7, 2022 at 10:14 AM Post #5,349 of 6,188
Hi everybody,
has somebody the same problem that everytime a new song plays it starts without mqa decoding and a second into the song it pauses for a millisecond and the right mqa decoding begins. This short pause in every song annoys me very much.
Has anybody an idea to solve this? I use an Fiio M11 Plus LTD and bitperfect mode.
Thanks a lot
Rob
Feb 7, 2022 at 10:35 AM Post #5,350 of 6,188
Fw 1. 20 and/or 2 prev version.
I can use uapp and NeutronMp and samsung browser in latest fw.
But it's not enough so i stay on 1. 20 for more degree of freedom.
Sideload with apk installer or apkpure app
Feb 7, 2022 at 11:02 AM Post #5,351 of 6,188
Hi everybody,
Thanks a lot
Rob
Yes, happens to me with my HiBy R6 Pro. In particular when switching from a previous non-MQA piece tp an MQA piece.
Feb 7, 2022 at 11:56 AM Post #5,353 of 6,188
You can try settings, MQA, MQA deep scan for local files and see if this helps. You'll need to rescan your library.
Feb 7, 2022 at 11:59 AM Post #5,354 of 6,188
I'd love to be able to do this with my SP1000M but I have no idea how to downgrade firmware (I assume through recovery). I also can't find any sources to download older firmwares. Ideas?
Feb 7, 2022 at 12:16 PM Post #5,355 of 6,188
You may found fw you want on a thread for ak sp1000 here on headfi.
Be careful: sp1000 (noneM) and M variant common in a thread.
Not to mistakenly flash fw of none M to your dap
