Nov 3, 2021 at 8:02 AM Post #5,161 of 6,408
Yes the version I have is 14mb. The zip file has 4 files in it. I tried to install from x-plore and SAI and I get the same result.
Sounds like you did it correctly. When I checked from x-plore mine was 14 mb as well (for the arm64_v8a version) with 4 files. I wonder if the new "Tensor" CPU is a different architecture (vs the Snapdragon 670)? I wouldn't think so...
Nov 3, 2021 at 9:25 AM Post #5,163 of 6,408
Nov 3, 2021 at 10:08 AM Post #5,164 of 6,408
Hi there. I have a Pixel 6 Pro and it appears that UAPP is not working with it. Not sure if Google has made a change that had caused issues with the other Pixels for a while and UAPP.
The app is not available on the Google Store on the 6 Pro, I assume removed by the Devs until fixed.
I am waiting on the November security patch which may or may not help. Fingers crossed.
Nov 3, 2021 at 10:35 AM Post #5,166 of 6,408
Nov 4, 2021 at 8:24 PM Post #5,168 of 6,408
I have reported the issue to Google. Hopefully if there enough they will do something. It has also broken Tidal and an external Hi Res DAC for me. Clearly something they have done (again).
I've also reported this to Google. Long time user here :(
Nov 6, 2021 at 11:51 PM Post #5,169 of 6,408
I've also reported this to Google. Long time user here :frowning2:
On a different topic, is there a way to force the output to mono?
Nov 7, 2021 at 12:36 AM Post #5,170 of 6,408
Select the 3 vertical bars, to access signal processing
Switch Off Bit Perfect
Select Balance
Switch On Mono
Nov 7, 2021 at 11:56 AM Post #5,171 of 6,408
Select Balance
Switch On Mono
Thanks!
When uapp works again on a pixel 6, I'll check it out.
Nov 8, 2021 at 5:34 PM Post #5,172 of 6,408
Got new Xperia 1 MK3.
Does UAPP not support direct DSD playback? DSD's do play perfectly in the Sony Music app.
Shows as below using HD Driver. Sound poor in UAPP.
Nov 9, 2021 at 3:07 PM Post #5,173 of 6,408
I have been using UAPP for a year and I am very satisfied, however I was wondering:
Is UAPP the only Android player that supports Qobuz or Tidal streaming or are there other apps too?
Another thing: with Qobuz everything is perfect, with Tidal I have problems, often the songs just don't start and numerous messages of failure come out.
I am using Xduoo XD-05 Plus as a dac / amp.
Nov 9, 2021 at 3:09 PM Post #5,174 of 6,408
Hiby does Tidal, but only UAPP does Qobuz as far as I know.
