magicscreen
I read on UAPP home that Loxjie E30 is working with UAPP. But my Loxjie D10 is not. They have the same XMOS 208 receiver chip. How is that possible?
Hi folks, just checking in with a quick question. Tidal's track radio function does not work in UAPP, correct?
Yes that's what I'm getting too.The function is there but it rarely works; most of the time it gives an error something like “track radio cannot be generated for trackid xxxxx”.
i suggest you use UPNP as i am certain your synology must be running a media server on it.hi every body
i used UAPP with my phone and usb dac ibasso it works very well with files in local .
but i want to stream my synology files by the app , i saw "network" in parameters but i don't know how could i fill it
Could you help me please?
thanx in advance
Now it is working.I read on UAPP home that Loxjie E30 is working with UAPP. But my Loxjie D10 is not. They have the same XMOS 208 receiver chip. How is that possible?
Thanx for your quick answer.
Where did i find a tutorial to set it UP?
TIDAL definitely shows up in HIBY Player though not all user defined playlists. Those do show up in UAPP. The hi- res adjustment in UAPP are more.mconnect HD supports Qobuz, and at one time TIDAL too, however I'm not sure if that still works as I only subscribe to Qobuz.
Hi all
When playing MQA files via Tidal, integrated in UAPP through my new MQA enabled DAC, I understand that I no longer get the green or blue MQA buttons as the signal is passed to my DAC for the second unfold or rendering as I think you call it. Instead UAPP reports it's playing an MQA track by showing the "MQA" symbol only.
My question is that sometimes the MQA symbol in UAPP is shown in "Black" and sometimes in "White". Could someone please explain what these colours mean?
Thanks
Any chance of adding negative values to ReplayGain compensation setting? It's a must for classical music. In Foobar2000 for example, I have to use -6dB RP amp gain and even then a few files risk clipping.
