RishiGuru
- Dec 24, 2010
Seems like LG has killed DSD/DoP playback on Android 10.
This is the main reason I'm back on here because I was looking into the V60 (to replace my V40)...but apparently LG has screwed the pooch yet again. PCM conversion is unacceptable for DSD playback because it defeats the whole purpose of this phone's audiophile capabilities! With this phone and quality headphones you can easily hear the difference.
Davy...any news on that front?
It is true that V60 or G8X does not support DoP, which signifies V60 is not able to transport DSD over its USB-C port. To transmit DSD data on a USB using DoP is to package the DSD data in PCM form. To be clear, this is NOT a data conversion from DSD to PCM. The data are unchanged. Now with DoP gone, LG Music app in V60 will convert DSD to 88200Hz PCM while transporting through USB. With my LG V30+ which is on Android 9 supporting DoP, the DAC on the other side of V30's USB connection must also be DoP compliant in order to reassemble the DoP PCM bits into a continuous DSD stream.
But in not having DoP support, does it mean V60 is not able to play native DSD files between its LG Music app and the inbuilt ESS DAC? There is no USB between the music app & the DAC.
I mean to say if I play a DSD file on V60, will the ESS DAC perform direct DSD conversion inside the ESS DAC? I think it should.
Please correct me if I am wrong.
