Vitaly2017
does any one know if apple iphone or ipad get the same crap with downsample like android? How can we stream bit perfect with any tidal song?
Probably, yes.
I have been juggling with the Audirect Atom Pro with IP5S and 11 via CCK. and playback downloaded tracks and streaming from IOS Tidal app itself and other FLAC files stored in the phones.does any one know if apple iphone or ipad get the same crap with downsample like android? How can we stream bit perfect with any tidal song?
But why when i play MQA original sample rate of 96khz only plays at 48khz as this picture below proves https://imageshack.us/i/pnhuVVf6pPretty sure you're unable to find the add on because your device should support MQA out-of-the-box.
You're hiding the now playing screen, mate. Whatever the metadata shows doesn't matter. It shows 48 kHz there because MQA unfolds 96kHz out of it.But why when i play MQA original sample rate of 96khz only plays at 48khz as this picture below proves https://imageshack.us/i/pnhuVVf6p
Thank you for clarifying to me pal, i really appreciate it as im not a seasoned veteran on high res stuff. Someone told me the G8x cant unfold MQA be cause in LG music app shows only 48khz on MQA files.You're hiding the now playing screen, mate. Whatever the metadata shows doesn't matter. It shows 48 kHz there because MQA unfolds 96kHz out of it.
(If I'm using MQA terminology incorrectly, you know what I mean. Decode, render, unfold, etc.)
I have no light on when im playing MQA files, interesting. Now i remember the light will not appear on LG devices with MQA capabilities.Ju
No worries, I would go off of whether or not you get the MQA indicator light from the now playing screen.
There are exceptions to this unfolding though, as I have an MQA album with mixed sample rates: 24-48kHz or 24-44.1 kHz, and only some of the 48kHz songs actually unfold to 96 kHz. The one 44.1kHz track doesn't unfold to 88.2kHz. They get the indicator light and all show the decoder as working. (I'm using the decoder plug in. Perhaps this is different with devices with built in MQA support *shrug*)
MQA is just messy <_<
I'd send the dev (Davy W) an email @ info@extreamsd.com about the issue, screenshot of now playing screen and the metadata one you showed.I have no light on when im playing MQA files, interesting
Sure i will email him and post any updates on this interesting issueI'd send the dev (Davy W) an email @ info@extreamsd.com about the issue, screenshot of now playing screen and the metadata one you showed.
MQA is very much in the spec of your phone, but I don't know if any of the DTS:X or Quad Dac system settings or EQ stuff interferes with UAPP?
